What oil filter?
Originally Posted by jct61765
What oil filter is everyone using? I've always used Fram, but I want to know what everyone else is using.
Thanks
Thanks
All I ever use is fram. It's not the filter that makes too much difference. I know this now after an API expert visited our school this past week and he was saying oil quality and filter quality doesnt really change much from brand to brand. It all depends on as long as you change them at regular intervals. I've been told by several technicians that oil filters dont matter too much as long as you change them often as you do your oil just so it doesnt get clogged up with gunk or particles. So reguardless of everyone's "opinions" any type you use is fine as long as you change them.
Originally Posted by mt_goat
How much are those Amsoil filters? Mobil 1 is a great filter too but at $11 or $12 each, I'll pass.
I always ran the k&n with mobil 1 But now I switch to AMSOIL oil and AMSOIL super duty filter. AMSOIL series 2000 0w-30 oil & sdf 57 filter. I can get you one for 8 bucks plus s/h.
http://www.puresynthetics.com
I used Toyota the first 30K miles. From there on I have been using FRAM. I just couldn't make it to the dealer to get the filter since my hours are different then their's.
I am currently using FRAM PH3614. Is there another filter out there that offers more filtering? Don't mean to steal your thread. I don't want to relocate my filter either.
#26
Just my opinion.AMSOIL. Check it out.
https://www.amsoil.com/storefront/sdf.aspx
#27
fram filters are terrible, because they let the oil drain back into the engine after it stops. this allows the engine to run dry when starting for much longer than other filters. i use a WIX 1515 filter, which is larger than stock but works fine, and holds oil in it while the engine isn't running.
#28
http://people.msoe.edu/~yoderw/oilfi...lterstudy.html take a look for yourself!
#29
That's very interesting. I would like to see what the k&n filter would do and what the out come of the AMSOIL is.
#30
Dosnt matter
if you want to get technical after about 500 miles the oil filter has a bypass valve and and the filter clogs and bypasses it so any oil filter is crap in my opion
#31
Originally Posted by SizzleChest
you guys that are using toyota filters, are you still able to buy the japanese made filters? the only ones that I can get are made in thailand. 22re.
#32
dude, that makes no sense at all!
jasonty
41
12-23-2018 01:00 PM
