thrid members
Originally Posted by deeiceman69
i would like to no if v6 third will fit into a 4cyl diff ....my prob being i bought a gear set for a v6
Originally Posted by 914runner
I am pretty sure that the gear sets are not interchangeable, but the complete thirds are.
Apparently you can. Check out the thread here,
http://www.pirate4x4.com/forum/showt...gears+cylinder
Hmmm, I had a rear third member gasket left over from my 85 22RE days, and it won't fit my '90 V6 third member. The '90 third member is physically larger than the old one was. So you might want to check carefully if you're thinking of putting a complete third member in your axle.
Yes It will
I have put a v6 third in my 4cylinder diff housing. They fit fine and are a little
bigger ring diameter witch means the pinon is alittlle bigger witch = stonger.
But as said the v6 gears will not a 4 cylinder third.
Greg
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
