SkyJacker 1st gen lift kits
I went to a local offroad store today just for ลลลลs and gigles and i ask for lifts for my truck..she says yea skyjacker makes two
4" which is $1000...screw that and 4" is wayyy to much
2.5" for $225 which used coil spacers....they dont make it anymore and im wondering if anyone knows where i can get one of these lifts?
well coil spacers in the front and a spacer on the spring mounts i think in the back....where are you getting your ome lift? what is it using?
hahaha thanks kyle good thing i didnt buy that kit from them....it sounds like they dont really know anything about yotas there...they didnt have ANY parts in stock for yotas nor did they know much...im gonna have them do installation if i buy a lift online anyways though...they cant screw me over no matter what because ill pay with a credit card...as long as theres not a rediculus insallation charge..
if there is..maybe a wrench-a-thon would be in order...although nobody around here mods yotas so i guess that wont work..
i dont trust myself with the suspension enough to do the lift myself...if i screwd up a little bit theres no going back to fix it when the axles fall off at 45mph...
Do some searching on YotaTech and on 4x4Wire for info on ball joint spacers for the front of your rig. They're about $120 and give you a 1.5" lift up front. Then throw some lift shackles in the rear and you can easily run 32"s. That's what I'm currently using. A lot cheaper than a 4" lift and it wheels just as good. Add a 1" body lift to that and you can clear 33"s.
06-01-2021 01:51 PM
09-04-2015 09:27 AM
coffey50
07-28-2015 10:55 AM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
07-06-2015 04:07 AM
