Question about mounting racks (Thule or Yakima) on tonneau
Should I do it?
I've thought about this for a while and it's getting close to snowboarding season. I want to mount a rack mount system on the tonneau for various reasons. 1) The whole thing is removable without much hassle 2) better mpg by not having your "stuff" so high up and they're also behind the cabin 3) Camper shell isn't an option for me 4) will fit in my low overhang work garage 5) etc...
I'm looking at purchasing these parts since I already have Thule crossbars.
1. Thule Tracker II
2. Thule Top-Tracks with Bolts - 60''
3. Tracker Kit
Has anyone done this here? I've seen a few of this setup before but being that my tonneau is not the most securely mounted object on the car it worries me to put any type of weight or potential wind sails on top of it. It's only mounted by two metal guides (not even hinges) towards the front, the hydraulic shocks, and the two locking latches towards each rear corner. I'm not sure if the fiberglass can handle the weight of 4 snowboards/skis and possibly two bikes and if a wind gust hits, will it stay on? I suppose if anyone has any educated guess or first-hand experience that would be very helpful.
I know Tonneau covers are built differently so opinions will vary. Mine is made by Innovation.
hmmm.. Yakima seems to promote installing it on a tonneau - http://www.orsracksdirect.com/yakima...ack-bases.html
1. Thule Tracker II
3. Tracker Kit
Just wondering, why does everyone always need to put the boards on top? They fit fine into the back of the truck. People always do that with surfboards too, I just keep mine in the back all the time. Unless I am going camping with a ton of gear, I see no reason to spend $200+ for racks!
I don't have a hard bed cover but I have seen a couple of Tacomas running around with a set up like you have described. They had a rail system mounted into the cover that was like a track I believe is something similar to this: http://www.rei.com/product/686210
coffey50
07-28-2015 10:55 AM
Athansinis
07-27-2015 08:38 AM
