New "BruceTS" style 3rd Gen 4Runner rear bumpers
#61
Here's a list of all the attached photo's from all threads in this forum on my bumper, including the build-up;
https://www.yotatech.com/attachment....achmentid=2417
https://www.yotatech.com/attachment....achmentid=2418
https://www.yotatech.com/attachment....achmentid=2419
https://www.yotatech.com/attachment....achmentid=2827
https://www.yotatech.com/attachment....achmentid=2369
https://www.yotatech.com/attachment....achmentid=2366
https://www.yotatech.com/attachment....achmentid=2360
https://www.yotatech.com/attachment....achmentid=2347
https://www.yotatech.com/attachment....achmentid=2346
https://www.yotatech.com/attachment....achmentid=2345
https://www.yotatech.com/attachment....achmentid=2342
https://www.yotatech.com/attachment....achmentid=2341
Here's a link to the actual Bumper Build-Up
#63
Originally Posted by FilthyRich
does your tailpipe clear the inner lip of the side flare when removing??
Does the side flare "flex" when you remove so it clears??
Thanks...
Thanks...
#64
Originally Posted by BruceTS
the tailpipe curves downward, so taking off the bumper is quite easy. A few jacks stands, then remove the 8 mounting bolts and it drops down. It's a one man operation to remove or install it. Even after all the pounding it took there was no problems refitting it after I finished painting. Considering the openning through the side is 4 1/4" and the pipe is 2.5 there was no issue of hitting. I assume when you say "side flare" you mean the side wings on the bumper?
As always thanks for your input
--Eric
#65
OK, I had a chat with a manufacturer on getting the parts laser cut and bent, until I actually get a CAD file done, I can't promise anything. I'll just say that the cost to get it done was half of what I thought it would be. The design will change to make it easier to install on rigs with up to 2" of body lift. I'm currently considering, not having the trailer hitch, but you'll still be able to use the factory one.
For now the total different laser cut pieces to assemble the bumper is 4 with 4 bends on a brake, but after the redesign it may go up a few parts.
I figured I'd toss this out to everyone for their input, before I proceed
The bumper will be made out of 11 guage (1/8") same as TJM or ARB
My original design used a 2x4x3/16" tube for the main beam, but the new design will be a "C" channel bent out of the same 11 guage, unless the trailer hitch is incorporated. There will still be shackle hangers attached, but will go through the bumper and welded to the frame mounts as well.
Some have questioned the actual strength of the bumper, my answer is if TJM or ARB's can handle most situations then there is no need to go heavier.
I'm still trying to decide if I should incorporate the stock plastic shroud or fill it in with a top plate. The goal is to make an affordable, easily adjustable, high clearance bumper for the average wheeler. Retail target price of under $500 is still possible.
BTW I've had a few offers to get the complete bumper produce and I'd get a royaity on sales, but this would raise the actual retail price, so for now I'll just try and do most of the work myself. If I can't get the AutoCAD file done soon, I was given a name of someone to do it for me, I'll have to find out the cost and see if it would be worth it.
#66
#67
I can also do AutoCAD, I just need to brush up on it.
Also, I vote for having a hitch and using the stock plastic insert. I imagine this is because I 1) don't have the factory hitch and 2) I want a hitch. also, the plastic insert give a very clean, professional, stock look. I think it really makes the bumper.
#68
It seems you've got the gauge and revised structural design pretty much set for this bumper.
From what I've seen, this bumper has a proven design. It does the job intended. Other bumper designs work well too. All the fabbed rear 3rd gen bumpers seem to offer much more protection than the stock unit. For those that don't buy your bumper based on the school of thought that angled corners work best, it's gonna be based on form.
What's left are minor issues such as retaining the stock plastic insert and a hitch.
I say keep em both.
That this bumper can work with that insert is one of its competitive advantages.
As for the hitch, I know I'd like one. As long as it's proven structurally sound and reliable, why not? Not that I regularly tow anything, but it's nice to have the capability when that need arises, and without having to deal with a separate hitch.
I say keep em both.
#69
I say keep em both.
I say keep em both.
#70
A built-in hitch to the bumper would be nice, but only if a 285 spare tire would still fit underneath.
I, personally, really don't want a big old tire hanging off the back or up on the roof.
Keep us posted - I know I'll be in the market for a rear bumper this summer!
#71
You know my feelings regarding your bumper Bruce.
I love the thing! Keep the hitch (it improves ground clearance , approach angle and allows for a larger under-car spare). Keep the plastic cover too (it gives your bumper a smoother transition with the original design and looks great).
I missed the thread on April 1st. I am glad I did, I would have been hyperventelating...
Bruce, Make sure you call me when this happens.
#72
what else would be cool is to have some recessed allen bolt slots on the side wings. these could be used to attach some temporary bolt on extra tubing for protection while wheeling. that way these extra "sliders" could easily be taken on and off, and while off the bumper would still have a smooth, clean appearance.
#73
I've been looking into making this bumper more user friendly by having the frame mounts separate from the bumper and using bolts similar to the way the TJM bumper mounts. Considering the 8 bolts on the front bumper holds strong enough to winch, I can't see any problems doing something similar for the rear. By making it this way, the bumper can be adjusted for 0-2" of body lift. It will be made so a 35" spare will clear the bumper, if you want to do the modifications to the frame, making one fit.
The reason why I was thinking about leaving out the stock plastic shroud is a slight rubbing issue with the rear hatch that can wear off the paint, something many users won't like. The stock bumper mounts to the body, so it doesn't move when the body flexes on the frame. The frame can deflect up to 2" if not more, so the shroud will come in contact.
I added a 1" weather stripping trim to the bumper that acts as a bumpstop and has prevented contact with the body, plus it hides the gap very well.
Another option is the exhaust port, should I leave it in or just weld in the ring and leave it as an option, so the end user can cut it out if needed.
The way the side wings are currently made, they clear 35" tires, but still follows the factory wheel well openining and shouldn't need to be changed for the different flare options.
Ok the trailer hitch will be installed, but it'll be stamped with a low rating or possibly "offroad Use only"
Another reason why I'm seriously thinking about producing this, is to be able to write-off my trips and all the stuff I buy. Getting a small business license is easy way out.
As for adding some bolt on tubes for additional protection this can be added quite easily in the future.
I have AutoCAD 2002 program and I'm very rusty on it's usage, considering I don't have much time, this portion might just be out sourced as well.
The bumper will probably be sent out for powder coating as well and I'm looking at building 20 bumpers in the first run to keep the cost down. Also looking at making this in a kit form, that the end user could simply weld together. This way I won't have to worry about the liability issues.
#75
Bruce,
I have always liked the design of your bumper. More power to you if you decide to produce these. I may actually want/need one...
What is the approximate weight?
My vote is to incorporate the plastic bumper trim, which may mean changing the design clearances slightly.
Andreas
Andreas
#76
Anything new here on this?
John
#77
Man, now that I have a 3rd gen, I want one of your bumpers Bruce. Please make some, even in kit form. I know people hat can weld, but fabricating a bumper like that takes time, something I don't have enough of to do something like this.
#78
if ANYONE could do a KIT that needs welded together...that would be KILLER.
There is a nitch market for these.
Hell, if the PLANS or drawings were even available, that could get things rolling for me.
but, as Schäêfêr has said in times past, getting these to fit on ALL 3rd gens with ease is the real issue. Fitment.
someone should do this
#79
I've been helping Lance with a 4th gen version, so I may farm out the AutoCAD work. By making the frame mounts separate, there shouldn't be any fitment problems between different rigs. One thing I want to make first is a template that I can go around a compare to other vehicles, similar to the way NASCAR uses them. I won't be rushing this product, so don't expect it to come out that quickly, unless I decide to go with the kit idea, then I could easily copy my original design and allow the end user to make the needed frame mount adjustments.
#80
