Mysterious Plugged hose
Just picked up a 1996 4runner, automatic transmission. While I was poking around under the hood I noticed that there was a soft hose about half inch diameter running up the drivers side of the engine right around the number 4 cylinder. Previous owner installed a separate trans cooler and disconnected the lines for the rear heater located under the passenger seat. I have a feeling this hose may be related but after scouring diagrams and shop manuals I have not been able to figure it out. It has about a foot of soft line and right around where the block meets the oil pan it goes to hard line and appears to run toward the passenger side. I tried tracing it underneath but didn't want to lay in the snow too long. Any ideas? I plan on doing a JDM engine swap in the future so I'm sure I'll find out its just been something thats nagging me. Will take pictures next time I'm out there.
Edit, took this screenshot from a youtube video, thats the approximate location and that line may or may not be it, hard to tell from the video
That is the breather for the front differential, does it have a breather cap attached to the top of it. Difficult to tell which hose you are circling. And save your exhaust when you do the swap, JDM engines cross over pipe go under the engine not over the bell housing like USDM.
Thanks, yeah it has a breather cap, and thanks for the heads up I've been looking at just stripping the jdm to a long block and then transferring all my US accessories. Plan on setting up two engine stands side by side and building the engine like that.
