My 4Runner Threw a ROD! *pics*
Old 06-26-2009, 09:46 AM
  #41
Hawkflyer's Avatar
some of these salvage yards are out of their minds! Check that Craigslist, I see 3.4's complete all day for way less than that.
Old 06-26-2009, 10:07 AM
  #42
91Toyota's Avatar
Sorry about your loss. I'd be looking for a new engine though.
Old 06-26-2009, 11:35 AM
  #43
Rock Slide's Avatar
Ok, found 2 more motors at a local yard...both out of a 2000:
122K miles - $975
118K miles - $1100
Both come w/ a 6mon warranty.
122K motor sounds doable.
Old 06-26-2009, 11:45 AM
  #44
Teuf's Avatar
Schaden freut, just kidding, oh the humanity.
So what is your plan, mmm i smell a rebuild.
Old 06-26-2009, 11:57 AM
  #45
Rock Slide's Avatar
Parting it out is no longer an option.
Sell it as is - Don't foresee us doing that.
Put another motor in it and drive it 'til the wheels fall off (or until another rod shoots out) - We've decided to go this route.
Old 06-27-2009, 01:37 AM
  #46
dbcx's Avatar
Originally Posted by FogRunner
Looking at the rod bearing surface in that pic it looks like there is a good amount of scoring/polishing from the crank. You normally only see that as a result of very low or total loss of oil pressure.
That's one reason I hate the idiot light and put in a oil pressure gauge.
Yeah thats nasty looking. You have had some other issues going on. You said the oil looked good, thats why you cant just look at it and say its ok it has to be tested. That looks like its been run low or hard a bunch. do you warm it up any in the morning before tearing out?
You were going to change it , did it happen to be low also?
Driving habits?
Oil brand?
Have you looked at any other bearings yet?
Maybe find a wrecked one that is being parted out in good shape
Good luck
Old 06-27-2009, 05:23 AM
  #47
Hawkflyer's Avatar
I agree that this didn't occur just out of the blue. If it would have "worn out", it would have knocked and been loud for ALONG time.
Old 06-27-2009, 06:06 AM
  #48
danimal92sport's Avatar
I don't agree with some of the posts here; high RPMs are not the only cause of rod failure. A loss of oil supply to the rod bearing will cause this kind of failure. The scoring of the bearing (in my opinion) is likely a result of this loss of oil supply, not necessarily something that took place over the course of months or years. The engine will continue to run (sometimes without much sign of a problem) for quite some time before something fails. I have seen this before (though not on a Toyota), and it was the result of a sudden loss of oil pressure and eventually the friction between the rod bearing and crankshaft bearing surface put enough stress on the rod that it failed.
My $0.02.
Dan
Old 06-27-2009, 06:09 AM
  #49
Hawkflyer's Avatar
This has caused such a stir, that should illustrate just how almost "unheard of" this type of failure is.
Old 06-27-2009, 06:12 AM
  #50
Rock Slide's Avatar
-Good idea. I might just get it tested.
-It's my wife's 4Runner. No, she doesn't warm it up in the mornings, but neither do I with my own. And no, she's not hard on it at all. She drives more like an old lady!
-No ,not at all. Still looked clean too. Just thought about changing it this weekend b/c it had been 5k miles since the last change.
Driving habits?
-Again, picture an old lady driving a buick and that's my wife behind a 4Runner.
Oil brand?
-Don't remember the brand, but it was not the most expensive oil, but it wasn't the cheap stuff either.
-Not yet.
Good luck
See comments above
My $0.02.
Dan
Dan, that does seem feasible. Like I said, the 4Runner had been driving great, until the very moment the problem happened.
I agree! Sucks I had to be the victim of such an occurance.
Old 06-27-2009, 09:07 AM
  #51
roger's Avatar
Wow that sucks Rock Slide. I think if I were you, I would 1) Call the insurance company, just in case that's covered; 2) Get a good junkyard engine if you can find one; or 3) If all else fails, get a rebuilt motor.
Good luck
Old 06-27-2009, 10:23 AM
  #52
raydouble's Avatar
How many miles between typical oil changes?
Sucks
Old 06-27-2009, 10:47 AM
  #53
Rock Slide's Avatar
Good luck
Thanks.
Called the Ins Co just to check, but they don't cover repairs of this nature. A few friends of mine said I ought to check out Mogi Ins b/c they cover stuff like this. However, it might be too late for that...
BTW, still searching for j.y. engines. Probably the route I'm going to go.
Sucks
Oil has been changed every 3K-5K miles. Never gone longer than 5K w/o changing it.
Old 06-27-2009, 12:39 PM
  #54
ARB1977's Avatar
Should of used synthetic oil, haha. I had a buddy who bought a used Mazda 3. One day the engine blew...caused by oil pressure loss. The shop tore down the engine and found sludge on the oil pick up screen. My buddy claims that running GTX cleaned up the sludge and caused the screen to get backed up.
Its possible that your 3.4L was the same way.
Old 06-27-2009, 03:20 PM
  #55
dbcx's Avatar
Originally Posted by Rock Slide
See comments above
You dont need to send it off now and test it it is to late. i you test it on a regular basis say once a year,it would of picked up a trend and you would of been getting readings letting you know something was going on. It didnt happen overnight it was an issue that was going on that you were unaware of. Thats why I push oil test and their importance it will let you know whats going on inside there. Running a 0w oil or a 5w oil can help on cold startups it is thinner at startup so it gets to where it needs to be quiker than a 10w oil hope you get it worked out soon
Old 06-27-2009, 06:55 PM
  #56
hurricanes99's Avatar
Smile
man I feel your pain!! I threw a rod in my 93' Cherokee a few years back. Mine was due to wheeling and attempting to go through about 4 ft of water. Water and oil don't mix to well....
Comments about the insurance taking care of it are pretty funny!! I love it when people suggest insurance fraud. I personally love catching people doing it .
Old 06-27-2009, 07:24 PM
  #57
desertyodaboy's Avatar
Wow that is the first time I have ever seen that on the 3.4 especially with such low miles. sorry to hear that
Old 06-27-2009, 07:36 PM
  #58
Hawkflyer's Avatar
BOO!........... way to ruin our fun!
Old 06-27-2009, 08:01 PM
  #59
Kiroshu's Avatar
i think someone missed too many old changes... you gotta change oil regularly. was you wife having it done on her own.... not to be mean or ofensive but i know women they will not do things they are supose to sometimes. i think she skipped oils changes and told you she was doing it...unless your at fault and did not do it.....she hit a huge puddle or something a suck water....unless its 1 out of 1,000,000,000,000 chance you got a defective motor i think its little care to truck from owner.... 5VZ's don't throw rods on purpose EVER! HOWS THE WARRANTY!!!! Call Toyota and see what they think.
Old 06-27-2009, 09:10 PM
  #60
Rock Slide's Avatar
lol, she never missed an oil change as I changed her oil every 3K-5K miles.
And no, she didn't hit any water...it's been dry here for a week. Only water around here is the water in the lakes.
No waranty either. I called Toyota...they said they've seen this happen once or twice before.
Quick Reply: My 4Runner Threw a ROD! *pics*
