If you had $5000 for only your truck, what would you do?
#83
Exterior
-15x8Streetlocks
- 33x10.5R15 BFGoodrich Mud-Terrain Tires
- SportRack Cargo Basket / Cargo Net
- Sylvania Silverstar Headlights
- Warn Receiver Hitch
- Tractor Lights for Rear Cargo Lighting
Suspension:
- Old Man Emu 901 Heavy Duty Rear Coils
- Old Man Emu N72F Rear Shocks
- Old Man Emu N98 Front Shocks
- Old Man Emu SD33 Steering Stablizer
- Energy Suspension Low Profile Bumpstops
- 1.5” Ball Joint Spacer
- 1” Roger Brown Body Lift
Others:
- Lockers front and rear (no specifics, it's still too far off in reality to start doing research)
- Sonoran Steel Rear Bumper
- TJM T-17 Front Bumper
- Stubbs Welding Standard SKO sliders w/ 15 degree cant
I only pray this is under $5000, although I don't think it is. This is my full out wish list as of yet...
-15x8Streetlocks
Suspension:
Others:
#85
Originally Posted by Cebby
Swap in a 1UZFE motor, ECU, a340f and dual ultimate - but I'd probably run out of money on that one too...
Kinda figuring this very same thing (see below)
and some new rubber....
Oh ya, and maybe a set of these....
#89
Fix my damn power door locks!
IPT Valve Upgrade
Get the first rear bumper from Mike
Make custom box setup in the rear where the spare used to be with:
All light relays
OBA w/ 2 tanks with the biggest compressor I can get my hands on
2nd Optima with tjm dual batt setup
Get new springs for my Downey Adjustables so its not sagging in the front anymore!!
1" wheel spacers and put my current DullerATs on my stock wheels for the street
Get either DestinationMT 33s or MTR35s for the Crawlers
That should do it... after that would come gears and lockers
IPT Valve Upgrade
All light relays
#90
IPT Valve Upgrade
All light relays
IPT Valve Upgrade
All light relays
#91
How much?
I would be doing lockers last because I want the oba first... and also it keeps me from going crazy on the trails. This is my DD for another year or two. Til then, I don't mind not having traction. Though... I made it over pretty much everything everyone else did at tellico and never needed a tow strap I'm actually the only one that made it up and around this big boulder that fell down at the bottom of 5 (in the creek) on the way home from my damn CV replacement.
#92
Probally looking at $800 O.B.O. shipped (weighs ~80#!!!) in a plywood crate w/ the third secured properly so the gears don't get beat on. Stock 4.10's professionally set up in the third. It would take someone less than 2 hours total to install. You then have your third as a spare or you sell it for $100 on ebay. It's been used offroad about a dozen or so days and actuated about once a month to keep the mechanism lubed. It's only seen ROYAL PURPLE gear lube, so you know it's just like new.
A new ARB RD23 is $700+ without shipping (prices have jumped big time) and then install is another $250 if you drop it off to have the third pulled at the shop like I did. I've got a new RD23, new RD90, donor third and front diff and 4.56's all expected to be here within the next 2 to 3 weeks... they will be bench installed into the donor third/diff, then i'll do the wrenching to put them on the runner.
#93
SAS.....
I have already spent about $3484 on mine.
had the 22r head resurfaced and cleaned some broken studs removed $105
9000lb magnum winch $554
Budbuilt crossmember $179
5.29's w/masters $520
Aussie locker $269 shipped
lockright locker $240
extended brake lines $89
Front birf rebuild kit $89
v6 calipers $135
FJ vented rotors $80
FJ80 Master cyl $129
Longfeilds $250
33x13.50 swampers $650
1.25 wheel spacers $99
Still want new springs/shocks and ubolt flip kit, longer slip ds, wider IFS rear axle, rocksilders, custom flatbed, winch bumper, oh ya and a newer 22re engine and w56 transmission.
#99
SAS
Hi-Pinion third
ARB front & Rear
For the 94
Newer 22RE for the 90
And if there is any left, new marker/ signal lights for the FJ40
5,000 US Dollars = 6,221.00 Canadian Dollars
Hi-Pinion third
ARB front & Rear
For the 94
#100
SAS (DANA 44)
35' Goodyear MT/R's
Safari Rack
WARN bumper front and rear
WARN 9000 winch
lockers front and rear
and definately regear with a V8 swap
maybe a new truck......jk
35' Goodyear MT/R's
Safari Rack
WARN 9000 winch
