Idler arm & Pitman -IFS 4 Runner
Hello Everyone,
i just buy an 1999 ifs 4 runner, lifted with 3" ball joint spacers and 31" tires
now the problem is the pitman arm is very short,and the tie road in extreame angle
i just found an sulotion (Total Chaos) but is too expensive for me
thanks everyone
thanks everyone
That looks like a 2nd generation 90-95 4runner. Easy way to tell is that 99s have a rack and pinion steering and a coil over shock setup in the front.
In the past on the second gens, a lot of people would run the autozone idler and there was a bronze bushing kit for it. Do a search for idler arm upgrades on here and you should get lots of ideas.
Is there some problem you are having with the steering or do you just not like the angle?
My fault, the idler won't help you. The extreme angle on the tie rod in the first picture you posted is from the suspension being at full droop. What does the angle look like at ride height?
the extreame angle is beacuase the shock is disconnected and the upper bumpstop is cutted
i don't have any problem with steering
