Hesitation at 2500-3500 rpm?
Old 06-10-2006, 12:26 PM
HOJU's Avatar
I'm starting to notice a hesitation when I get to 2500rpm or so.... It acts like it's getting staved for fuel but then it also acts like it's choking. After 3500rpm it seems fine. I've thought about the MAF, plugs, fuel pump, hopefully not the tranny.
Any tips or suggestions would be great.
Old 06-10-2006, 06:24 PM
Elton's Avatar
i would do a tune up and clean the maf then go from there
Old 06-10-2006, 06:45 PM
Jonathan's Avatar
Is your's a 5-speed? Mine has been doing the same thing, but usually only when it has been sitting for a while, like overnight. I can't figure out what it is so if you find out let me know.
Old 06-10-2006, 07:02 PM
HOJU's Avatar
Jonathan, It's an auto.
Elton, That's kind of what I had in mind. I even had a suggestion to do a fuel system flush
Old 06-10-2006, 07:03 PM
Elton's Avatar
also may try a new fuel filter
Old 06-10-2006, 07:23 PM
HOJU's Avatar
Yeah, forgot to mention that one....
Old 06-10-2006, 07:52 PM
WHORERUNNER's Avatar
Did you check your air filter??
Old 06-10-2006, 09:00 PM
HOJU's Avatar
first thing
Old 06-15-2006, 04:16 PM
HOJU's Avatar
Ok, I've cleaned the MAF, and air filter, and have replaced the fuel filter....
still nothing-
Old 06-15-2006, 04:19 PM
Elton's Avatar
did you change the sparkplug wires and plugs yet ????.........i just did a tuneup on my 4runner 129k on stock plugs and wires it ran fine before but it runs way better now
Old 06-15-2006, 04:21 PM
Elton's Avatar
o you have a supercharger did you do the fuel mods
Old 06-15-2006, 04:41 PM
waskillywabbit's Avatar
Swear at it and kick the tires.
Old 06-15-2006, 05:20 PM
HOJU's Avatar
Done a LONG TIME AGO.....
Old 06-15-2006, 05:23 PM
Elton's Avatar
have you done the supra maf swap yet ?
Old 06-15-2006, 05:47 PM
984RNR's Avatar
if you have a s/c w/ no fuel mods that would be my first geuss that you're starved for fuel. or plugs
Old 06-15-2006, 07:46 PM
HOJU's Avatar
I've had the charger for almost 2 years with no issues. I've thought about the supra maf swap, but it's been suggested that you need fuel mods in order to do it.
I took it to auto zone and no codes came up. The guy there has a 4runner and thought it could be the TPS....
Old 06-15-2006, 07:48 PM
Elton's Avatar
so did you get bigger fuel injectors?
Old 06-15-2006, 08:06 PM
HOJU's Avatar
nope...
Old 06-15-2006, 08:07 PM
Elton's Avatar
well i think thats part of the problem
Old 06-15-2006, 08:10 PM
HOJU's Avatar
I think that if it was a problem it would have happened soon after the charger went on, not almost 2 years later.... they might need a good cleaning, but I don't think they are the issue at hand
Quick Reply: Hesitation at 2500-3500 rpm?
