Help Broke a Brake Line !!
Old 02-16-2004, 10:16 AM
PirateFins's Avatar
Hey guy's,
While working on my brakes this weekend, I was trying to free a stuck caliper piston, which is still stuck and to make a long story short, I now need a new caliper and a new section of brake line that connects to the caliper. It is the hard steel tubing that connects thru a fitting the brake hose on one end and the caliper on the other. You can see it here in a pic Cebby posted. It is the line that is connected to the caliper, and has the black plastic covering half way up it. Any help as to where I might be able to obtain a new line?
Also when I replace the line and the caliper, should I bleed all 4 brakes? I caped the broken line, to minimize fluid loss.
Thanks,
Brad
Old 02-16-2004, 11:04 AM
toy283's Avatar
You will probably have to get another line from a boneyard. The dealer may carry such an item but not a parts store. A parts store will carry straight line in various lengths that can be bent up to fit but no pre-bent pieces.
As a rule you should always bleed all the brakes whenever you break the system integrity. In this case, the rears won't take much but you should still do them.
Old 02-16-2004, 11:10 AM
Shane's Avatar
Dealer can most definitely get it for you, but it will likely be special order.
Old 02-16-2004, 05:19 PM
joez's Avatar
Dealer here actually had one in stock for my '83, it was a $6 part.
Old 02-24-2004, 05:51 AM
PirateFins's Avatar
Thanks for the advice. Ordered it Friday and got it yesterday. Everything went back together anf truck is back on the road. I never knew that a $6 part existed at a dealer.
the1998sr5
15
07-14-2020 08:35 PM
oldirtydirt
02-23-2020 09:30 AM
09-04-2015 09:27 AM
87turboPA
07-12-2015 07:49 AM
87turboPA
07-09-2015 05:58 AM
Quick Reply: Help Broke a Brake Line !!
