difference in spacer lift or new springs?
I am worried about cv stress and am having a tough time figuring out if
a 2.5 or 3 inch spacer lift is any different than OME springs? even if I go with a 2" spacer lift its way cheaper than springs, I just don't understand the difference. Is it the ride difference or handling, why spend extra for the same concept? please help me understand the difference. I searched and couldn't find anything! thanks!
There is a pretty big difference between spacers and new springs not just from a dollar perspective, but from a ride one as well. The spacer (cheaper) stiffens up your stock spring while most after market springs are progressive and made to work at their specific height. IMHO, it's much better to go w/ new springs even though I have a spacer lift. I went the cheaper route...
Originally Posted by ebelen1
As far as CV stress, it's the height of the spring or spring w/ spacer that matters. From all I've read, more than 2.5" will cause you problems. Some have more than this w/ little issue but I wouldn't risk it.
I had a spacer lift on my tacoma and the ride was better than stock. I am fine with what the ride is like with spacers but am really considering OME springs and shocks but can't seem to figure out if double the money is worth it even if i will have the same CV problems in the future. any help would be appreciated. thanks
My ride stiffened up quite a bit from stock w/ spacers and Bilsteins. It is better than stock but I would think that a progressive spring made for its height would ride and handle better than a stock spring w/ a spacer in it.
Springs are just one component of your suspension that will affect your ride. Did you also change out your shocks when you put in the spacers on your Tacoma? Maybe new tires?
if a spacer lift is going to give me the same life out of a cv than a new larger spring then I will save the money and buy spacers, but if I gain something from new springs then that is what I will do! Just looking for a reason to spend more money or less for the same problems!
my main worry is the cv angle and how long it will last with 1 or the other.
Flying91
45
04-11-2024 04:39 PM
09-04-2015 09:27 AM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
coffey50
07-28-2015 10:55 AM
terminator
07-27-2015 07:13 PM
