diffarential lowering kit
hi-new here-great info resource forum-good people. this is probably a dumb question but here goes-in the diff. lowering kit there are washers and cylindrical spacers about an inch long.do you use the washers or the spacers between the trans.mounts and the frame-or do you use both?
not exactly sure what ya mean, heres mine
and welcome to yotatech!!! remember to search, for the most common questions... including this one, will probably be covered several times, also, where did you buy this? for reference there may be people with same exact kit that will chime in
Requesting immidiate help! I am in the process of putting in the diff spacers (1'') and well I cant get that thing to drop low enough to put the spacers in place. :cry:
It looks like the vacum valve or what ever is holding it up on the cross frame part. What do I do???? I have a 96 4Runner. Im stumped.
Would it be safe to pull out both bolts and nuts? or would it fall down to far due to no support???
Thanks.
Thanks.
Well I just completed installing the Diff drop and a 3'' spacer lift on my 4R, I realized I had to drop out both bolts to get the spacers to fit, Guess and working on vehicles dont mix the best .
I'm very pleased with how it looks, and ill post some pic hopefully soon and let you guys know how it rides. thanks all
jerusry
10-19-2015 05:28 PM
justdifferentials
Just Differentials
09-17-2015 06:14 PM
09-04-2015 09:27 AM
kirkrunner
07-27-2015 07:59 PM
