A Beginner's Thoughts on Body/Suspension Lift and Tires
Old 03-15-2006, 05:24 PM
foxtrotuniform's Avatar
Originally Posted by potsy
thansk for the write up. specifically what part # OME shocks and springs did you install?
881's and 891's springs. I don't remember the number of the shocks offhand. I may be able to track them down though.
Old 03-15-2006, 06:17 PM
BigJohn's Avatar
How is the Ride Compared to stock is it more stiff, is it more comfortable did it give you more fender clearance ,the suspension im talking about
Old 03-16-2006, 12:26 PM
From Above:
One noticable difference is that it runs much smoother on high speed gravel and dirt roads. No bottoming out any more, and I cary tons of weight back in the rear. If you spend lots of time on the gravel, I'd recommend the suspension even if you kept everything else stock.
Another noticable difference is a crummy ride on the interstate. As with any real off road vehicle, road noise increases with the tires. The higher center of gravity tends to make it a little less stable; It definately takes a little more steering to keep it in the lane at interstate speeds.
But I'm a guy. I don't care about stuff like that. Looking at the beefy thing in the parking lot gives me more enjoyment than any smooth ride ever did. If you care about smooth ride...well, I probably wouldn't do any of these mods.
Rougher on the road, smoother off road...Hmmm, does that make sence?
I got more fender clearance. The suspension makes the front set a couple inches higher, and the rear about 3 inches. You're not going to be clearing 35's (or 33's without some creative reshaping) but with the body lift on top of it, I have no trouble clearing the 33's.
Old 03-16-2006, 10:36 PM
BigJohn's Avatar
so the ome is a worse ride onroad then stock, if thats the case i will jsut save my money and keep stock
Old 08-07-2006, 09:37 PM
  #25
scottpray20's Avatar
Does the 4runner have the same suspention setup at an 86 yota pickup
Old 08-08-2006, 07:18 AM
  #26
BajaRunner's Avatar
Nope, not even close.
86 P/U has torsion bar front, leaf rear.
3rd gen 4runner has coil-over front (aka struts) and coiled rear
Old 08-08-2006, 07:54 AM
  #27
04 Rocko Taco's Avatar
Originally Posted by garrett1478
now here's a guy who joined the board a month ago, has a total of 5 posts, and has earned my respect in the time it took me to read this thread.
Absolutely!!! Very Nice Write Up!!
Old 04-10-2008, 07:51 PM
  #28
elburritobandito's Avatar
Thats debatable. His rig has an additional body lift and some seriously aggressive tires (which look really nice). I doubt that the ome coils/shocks by themselves would give a lousy ride. If you are concerned about it dont use the extra 2" body lift and a put on a bit narrower tires. Should ride fine.
Just my $0.02.
Old 04-11-2008, 07:48 AM
  #29
aclark092's Avatar
Very Nice, I may be doing the same set, only using a 1" body lift, and not quite as big of a tire.
Old 04-11-2008, 09:10 AM
  #30
jake the snake's Avatar
Amazing write up....I may end up doing your setup to the T. I've been looking at lifts a couple of weeks now. Also i'm Graduating high school in a couple of weeks and i'm looking at also going into the Air Force. I'm just not real sure if i should go or not?
Old 04-11-2008, 09:17 AM
  #31
mkgarrison5's Avatar
this thread is 2 years old.. but man what a sweet ride and a sweet write up to boot
Old 04-11-2008, 09:25 AM
  #32
2000t4rAKS's Avatar
FU,
Awesome write up man...Your rig is a beast. When I was in tech school down in Pensacola, FL I would always use the Auto Hobby Shop to help my buddies out. Thanks for serving your country. I myself was in the NAVY from 2002 - 2007. Jake, if you are going to join any branch of service, the Air Force isn't bad. Us aviation NAVY guys always made fun of them because they have it so good, but thats because we were jealous.
austin
Old 04-12-2008, 05:20 PM
  #33
Doublewid3's Avatar
NICE! I like the BL on it. Gives it more tude. I want a 3in on the suspension and 1 on the body. For 4 inches. Can i do that? 1 on the Body 3 on the suspension without having to do lots of modding? And w/the BL it looks like you can get the oil filter easier, i go though my driver side tire to get to mine...skid plates way banged up to remove.
Flying91
45
04-11-2024 04:39 PM
09-04-2015 09:27 AM
coffey50
07-28-2015 10:55 AM
PlayAwhile
07-20-2015 11:36 AM
Edionne13
07-09-2015 01:59 PM
Quick Reply: A Beginner's Thoughts on Body/Suspension Lift and Tires
