Amp question
Originally posted by rowan
thanks prerunner.
my sub box is totally closed up... should i put a port in it somehow?
thanks prerunner.
Nope, leave your box the way that it is. If it does not have a port then it was not designed to work with one. The port will change the airspace in the box and will totally change the way the subs sound. They will get very sloppy and the recovery rate wil be terrible. Highly undesirable, unless you listen to nothing but bass demos. In that case, knock yourself out. Drill all the holes you want.
Noel
rushw
07-18-2015 01:46 PM
