5VZ + TRD Supercharger, cant stop the ping?????
You are for some reason tring to reinvent the wheel, why not just take what has proven to work very well for many others and use that? I realize you have a lot invested now in your invention or trail blazing. Good luck mate.
Ok, lots of good points! I'll try answer as many as i can.
I dont see the point in running a larger injector when:
a) the A/F ratio is fine. (approx 12.0:1)
b) the injectors are not maxed out
As mentioned, I am not running low octane gas, and the spark is plenty retarded.
Actual timing has been checked with a timing light, and is in check.
I understand that tuning it on race gas may well solve the problem. But this is not a 'race car'. Its a 4x4, that gets used in 4x4 territory, meaning race gas is not always available. Atually here in Aus, its very rarely available.
And the plugs are being checked.
Not trying to re invent the wheel, I bought SC kit and Gadgets 7th injector kit....
Tried it with NO luck, and THEN switched to the standalone....
Only other thing i can think of is carbon build up in the cyclinder that is causing it to ping. Or oil. Either way both would be from an engine that has been used for quite a few miles.
#25
Well yeah, being a 'relatively' low mile engine, that has been serviced at 5000km intervals, I wouldnt have expected that.
Regardless, I did give it a clean with the stuff you guys call Seafoam.
Unfortunately it did nothing
#26
Have you tried going lower? Like maybe 11? Because Gadget once told me 12 is really too lean for a heavy 4x4 at high boost and WOT. Not sure how your rig is set up. Also do you guys have alcohol in your fuel down there? The stoichiomertric ratio of alcohol blended fuel can be lower than pure gasoline.
Also when do you notice the most pinging? Low rpm, high boost?
#27
Have tried right down to 10:1 and everything in between.
If it was as simple as adding more fuel, this thread would never have been started
The truck runs 4.88 ratios, 35's, big lift, F&R lockers etc etc
Heres a pic for reference:
The pinging occurs in the typical low rev/high load fashion.
So mostly in between 2000 and 3500rpm.
As for fuel, like i said before the aim is to have it up and running on our regular premium fuel. 98RON.
This truck is sending me insane!!
#29
Coolant temps have not changed at all since the SC install, and it runs the standard TRD pulley which from memory pulls approx 6psi.
Was originally running a URD 2.2 pulley (which i had fitted at the same time the SC was first fitted) and we removed it because we thought it may have been the extra boost that was causing the pinging. But after swapping it back for the stock pulley, we noticed virtually no difference.
#30
You shouldn't have any problem running a stock pulley with the factory ECU and URD kit. I'm running a 2.1" pulley with mine (over 10 psi of boost) and no ping that I can hear.
#31
You might consider doing a fiber optic video inspection of your cylinders and pistons, just to make sure there isn't any visible pitting or damage to them.
#32
Been thinking about this post....
I had the timing belt changed about 10,000kms before the SC went in.
Do you think the timing may be a little off? I wonder if thats what it is.....
#33
Since the last post a 2mm Cometic Head gasket was ordered, and the decision was made that whilst we were at it, we would open up the heads a little to a) Increase flow and b) Decrease the compression ratio even further.
Here are some pics of the progress on the heads:
The engine will be going back together with ARP head studs, and we have also decided to ditch the standard valve springs and retainers. We will be using Brian Crower springs and titanium retainers.
#34
Interested to hear everyone's thoughts on whether or not lowering the CR will solve the pinging problem???
I guess many people might see it as somewhat of a 'band aid' fix, but it seemed like a better/more cost effective option than building the engine.
#35
Will it fix it? It depends on what was casuing the ping int he first place. SOMETHING was not right.
I just installed my Supercharger and even with the bone stock ECU and it still in learning mode, i never got any ping.
I still think that your timing is off.
#36
Did any of your spark plugs have strange build-up on them? I was thinking that if one bank of cylinders had more buildup or burning than the other, it could be a sign of a skipped tooth on the cam pulley for that patricular side.
Like Texas_Ace, I'm still suspicious of your timing, and since the engine is apart anyway you might pull the timing cover and set the crank to TDC and confirm the cam pulleys are in the right spot. Even being off by a single tooth on the belt could be causing all of the problems you're seeing. Resetting your timing belt by taking it off and following the install instructions is probably a good idea just to be sure that isn't your issue.
#37
Well it all went back together, and the pinging has stopped!
Now its running 20 degrees of advance where it used to run none... HEAPS more midrange torque!
The drop in compression dulled the engine a little though, so I have changed to a 2.1" pulley to compensate. Power is now up from what it used to be so I cant complain at all!
My question is....
Whats the reliability of the TRD supercharger like with the 2.1" pulley?
Keeping in mind its a big heavy truck.....
My question is....
#39
On a stock compression engine that's true. However, he's running lower compression now so it could be that he's ok. The only way to know for sure is to have have a look at his EGT's.
#40
Any word on this?
I had my truck tuned by "Gadget" himself.
Was a nice guy and all but it felt like I was left SOL and with a nice empty wallet to boot.
I work with an awesome mechanic now in an unrelated field and we are going to try and trouble shoot this POS or go back to stock.
My truck was fairly new when the URD kit and S/C were installed.
Gonna pull the plugs and check gaps and such and maybe go one step colder than the two step Denso plugs that came with the kit.
Always getting misfire codes, and after the years and aweome help coming along... I want to solve this issue once and for all. And to think the truck ran fine and in boost before the URD kit...
Cats have been replaced a few times, and they need to be replaced again.
(I'm NEVER on here anymore, but I do browe from time to time to see what's up)
