4wd vacuum leak?
Old 01-07-2004, 10:16 AM
surferfrank's Avatar
Question 4wd vacuum leak?
Could someone give me some advice on how to diagnose and fix a 4wd problem on a 1990 4 runner?
My 4wd light flickers and goes out on the dash. I thought I had 4wd, but I got stuck in Lake Tahoe this weekend. I had to put on chains!
I'm not sure how to fix a vacuum leak or the add system, but I'm willing to try. The friendly folks in Minden told me "the 4wd diaphram is leaking". Not sure what that means: Replace vacuum lines or the add system? How much are replacement parts?
I want to check in here before I drop more money into my truck.
thanks
Old 01-07-2004, 10:33 AM
mt_goat's Avatar
This may help http://www.4x4wire.com/toyota/tech/add/ if you want to defeat the ADD system.
Old 01-07-2004, 11:07 AM
Memphis4X4's Avatar
Using the Search Function I Found This
Actually, I used the outstanding search function that Yotatech has to find a post that I had made in an old thread which helps answer part of your question. Try this Thread
See if this helps. I fixed my 4wd using this method and all that was wrong was one of the vacuum hoses had a hole burned in it. If you light is flickering it might be engaging and then the vacuum is bleeding down and disengaging.
David
Old 01-07-2004, 12:22 PM
sounds like it might work...
thanks...It looks like a vacuum leak from the thread you posted.
Where it's leaking is the big question.
I'm not sure about defeating the add system. It sounds kind of complicated.
Hopefully I'll be able to fix this problem before my next trip to the mountains, otherwise I may have to chain up again. :pat:
Old 01-07-2004, 12:37 PM
Memphis4X4's Avatar
Defeating the ADD typically means that you convert to manual hubs. That requires money. Instead, I would troubleshoot the vacuum system just like I wrote in the other thread. The vacuum leak is not some major leak in your engine but will be somewhere at or after the vacuum solenoids that I refer to. Most likely it's at the vacuum canister in the passenger side wheel well. The leak will proably be due to a dry-rotted rubber vacuum hose or a hose that has been rubbed by brush while off-roading. That happens a lot to these hoses because they are in the wheel well and can be easily damaged. But......that's any easy fix.
David
Old 01-08-2004, 08:46 PM
still not working...
I looked at the vacuum lines today following the last post. I found that the vacuum lines both draw air, yet the 4wd still doesn't engage. The light still flickers and goes out.
Any more suggestions before it goes to a repair shop?
I'm wondering if the ADD system has a leak inside. I want to be sure before I buy a replacement.
thanks for the help...
Old 01-09-2004, 09:54 AM
Memphis4X4's Avatar
If you have vacuum at the diff then it most likely isn't your ADD. The problem is probably in your Transfer case. Click on the copy of the FSM section on the Transfer Case .
This is getting out of my area of knowledge. I let my transmission shop service my transfer case. If the FSM doesn't help, take it to a trusted tranny shop.
David
Old 01-09-2004, 12:42 PM
thanks..
thanks for the advice. I'll try switching the lines just in case, but it looks like a transmission repair job($$$).
Old 01-22-2004, 10:09 AM
Talking 4wd vacuum update and happiness
Just an update...
The vacuum problem ended up being a switched vacuum line at the transfer case. They are color coded and the engine rebuilder switched the lines.
Thanks for the info. It helped me figure out this problem.
Old 01-22-2004, 11:27 AM
Memphis4X4's Avatar
Great Job!!!!
Isn't it a good feeling when Yotatech helps you fix something and you don't have to take it to the dealer and spend $$$$.
I'm glad you got it fixed!
David
raptor510
02-17-2017 07:11 AM
_Nicco_
08-28-2015 07:26 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
TokyoD23
07-12-2015 06:01 AM
nick b
07-11-2015 04:38 AM
Quick Reply: 4wd vacuum leak?
