Last edit by: IB Advertising
Browse all: Toyota 4Runner Brake Guides
- Toyota 4Runner 1996-2002: Brake Modifications
Overview of popular modifications to help you customize your 4Runner.
3rd Gen Brake Upgrade - No more warped rotors
#41
it is most likely just the angle but it looks like his "new" tundra pads are thinner than the "new" 4runner pads. the tundra caliper does appear to be larger, or at least shaped differently at the bottom. i may have to head up to the dealer so i can see the difference in the piston size.
#42
It's because the rotor is so much bigger it makes the pads look smaller in width.
Someone needs to get a shot of the rotor with a ruler on it. That way you guys can see the difference.
#43
Originally Posted by socal98runner
Optical illusion....
i actually have some used tacoma rotors out in my garage, they are off a 15" wheels truck but will probably be the same diameter. i will try to get my hand on some calipers and measure them too.
#44
Originally Posted by saletel
there are 2 different kinds of dot 5 fluids, one is compatible, another is not sorry im too lazy to look this up i am pretty intoxicated
In Europe, they never really recognized DOT5 (silicone based) as a brake fluid. Rather, they call DOT5 what we call DOT5.1. This, as you can imagine, causes many headaches for owners of some European vehicles, where the owner's manual declares "USE DOT5 only" but is referring to the European DOT5, or the US DOT 5.1.
But, in our vehicles, DOT4 is the best fluid to use for the brakes.
~Mystickal
#45
Originally Posted by Praufet
http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW
Here is a little upgrade for all you doing the swap.
EDIT: I forgot to mention that the holes make your disk crack easier..
#46
.....::waves hand:: These are not the rotors you are looking for.
Move along.
Move along.
#51
Originally Posted by StingRay
With this upgrade are there any effects on the ABS system?
So off I go to the dirt lot to see what the ABS would do with the new brakes...
Guess what? It works perfectly!!! Maybe even better than before.
So, in conclusion - ABS - OK!!!!!
#53
Originally Posted by Gangus2006
Actually, Drilled rotors are no upgrade...its sort of a downgrade. Drilled rotors were invented because brake pads used to release a gas, preventing them from fully seating on the rotor. The holes allowed the gas to escape. Today, brake pads no longer produce that gas, so the holes are no longer needed. All they do is look good. But they do take away some disk surface that can be used to stop your truck faster...
i DISAGREE...
lemme start my story. 90 4runner. OEM type rotors would warp, no matter what every 10-12 months.
after getting severe vibrations whenever i hit the brakes, was a sure sign the rotors needed replacing or turning (yeah i know...)
finally, when the last OEM type set couldnt be turned anymore, i went with genuine cross drilled brembos.
that was what... 5-6 years ago now?!?
no vibrations. gone through 2 sets of front pads. no cracks either. havent had a need to turn them either.
now these are FORGED holes in the rotors, not DRILLED after they were made.
now fast forward to 2004. in my subaru STi, you know about the brembo brake setup in there.
my problem with it is when it gets wet. driving freeway speeds and hitting brake pedal and it feels like i have no brakes. i mean i freaked when it was pouring and a car cut in front of me in the freeway!
a second later, i hit the pedal again and it seems to be back to normal.
i tested and repeated that. it seems that when it gets wet, the water between the pads and rotor... well doesnt compress well.
i know when these front rotors go, i'm with genuine cross drilled or slotted.
#54
So I never even thought of that when I installed them.... stupid me...
#57
Originally Posted by ColImport
now I went to a junkyard to get the tundra calipers and they asked me if I needed the
the 199mm or the 231mm.....which ones did you install???
Both should fit fine but you would like to get the newest version (better stopping power).
#58
now I got 16" wheels but the original on the truck where 15"...I am fine as long as I have the 16" right??
#59
they said that both 199mm and 231mm are from tundras 2000 and above, I would love to get the bigger ones but dont know if they would fit even after shaving the dust cover?? any pointers?? MTL? thanks for your help!
