01 Runner; Timing Belt Marks NOT Aligning with Crank Marks
Old 01-12-2016, 06:40 AM
Redrezzer's Avatar
Getting ready to change the timing belt on an 01 4Runner; at TDC on the crank, the cam pulley marks don't line up with the rear timing cover marks and are off by about 1"-2". When the cam pulley marks are lined up with the rear timing cover marks, the crank marks (dimple on and notch on pulley assembly) do not line up with oil pump and lower timing cover marks; they're off by about the same 1"-2" as the cam pulleys. I've rotated several revolutions on the crank but still no luck in lining up the cam pulley marks even with the crank timing marks. With the engine being a "non-interference" engine, can I just set the Crank at TDC, cut the belt off, and then re-set the Cam pulleys separately? Any and all guidance/suggestions are appreciated.
Old 01-12-2016, 07:09 AM
vasinvictor's Avatar
Non interferance. Take belt off, line up marks, install belt. Customer will be amazed how much more power there is!
Old 01-12-2016, 09:21 AM
Redrezzer's Avatar
thanks for the intell....!!
yotapwru
Washington
02-15-2019 11:47 AM
Mattluke1
10-31-2015 07:16 AM
tsh2014
10-28-2015 11:48 AM
ashersullivan88yota
10-27-2015 02:53 AM
odonekanobe
10-15-2015 04:55 AM
Quick Reply: 01 Runner; Timing Belt Marks NOT Aligning with Crank Marks
