89 4 runner winter build up thread
this is Just my opinion. the BJ spacers are ok as stated see if you can relax your tortion bars and see where that sits the front then level out the rear.
I don't think your gonna be able to weld the blocks, one looks cast and the other looks like alluminam but I could be wrong.
is there body lift on this as well?
I'm not gonna lie, that thing looks pretty sketchy as it sits now. The body looks like it's shifted slightly off-center from the lift, but that could be the camera playing tricks. The rear blocks look downright dangerous. Your CV angle looks terrible; the pics look like both inner boots are torn. It looks like something weird is going on with your LSPV, too. And you probably already know your e-brake is disabled.
There's plenty of potential there, though. It just needs some TLC. For any help you need, you've come to the right place!
#26
thanks for the input, im getting a little ahead of myself here but i had some down time at work and mixed up some custom paint i think i want to paint the runner. its kinda a slightly off white with a blue pearl overlay. kinda hard to see in the pic but you can see the blue where the metal bends. looks white straight ahead but shifts to a pearl blue. let me know what yall think.
#28
#31
so she got some new shoes today, sorry for the bad pic its raining and dark, but they look awesome. finally finished "de-hailing" my wifes car so now its time to really start working on mine. next on my list is gears. this things sucks driving around all the hills around knoxville. and i was thinking to fix my nasty lift block problem in the rear, just removing the smaller block and adding a couple leafs? if anyones done this let me know the blocks about 2" so just wondering how many leafs i should put in to make up for it?
#32
The # of springs will depend greatly on what springs you use, how long, how thick, spring rate, etc. Your probably just going to have to experiment some till you get what you want. Shakles might be an option to.
#33
ok so ive heard of this "zuk mod" now. would removing the 2 inch blocks and putting in 14" springs compensate for it? maybe lower the torsion bars in the front if needed. if anyones done something similar, input would be appriciated.
#36
yeah but im only gonna make up for two inches, i have a 2 inch block and a 3 inch block in the rear, im gonna take out the 2 and leave in the 3.
#37
I just did the zuk mod on my 86 I used the rear springs out of my 97 cut 1 coil off. I gained around 2.5 inches of lift. cant tell you much more than that man becouse I just finished it up LOL.
#39
so i got my front and rear ring and pinions in the mail today. i plan on installing them myself, but have never done it. anyone know of a good write up on here about it? tried searching with no luck. or if anyone has any advice. i plan on tearing it down next weekend.
#40
Zuk's website will give you a good idea of what you're in for.
http://gearinstalls.com/
