Hayes' 1985 4Runner Build-Up Thread
I am starting to piece together my 'Phase One' build components. So far I have 33x1250x15 Mud Terrains and Wheels at my house. Waiting on my lift to arrive, and once that is in I will be ordering a hy-steer.
After that and the bank account fills up a little more I am going to be getting complete 3rds, bumpers, sliders, OBA...
There are going to be some misc. things to go in as well...guages (tach, trans temp, coolant temp, oil pressure).
Pics!
Here are the wheel that I got. They are 15x8, 6-5.5 with a -19 mm backspacing.
The tires...notice the Christmas tree next to them? Christmas in April!!
And more or less what they will look like mounted up.
Brandon
Pics!
Brandon
Well, no. I got them at Discount Tire and I'm an assistant manager so I get a smokin' deal. I didn't pay too much less on the wheels than normal though. The tires is where I caught my huge break.
I was told @ Discount Tire here in Phoenix that they couldn't mount 12.5" tires on 8" rims anymore. Is this true or are you just lucky cuz yer the Ass Manger?
John
John
i mounted some of those wheels on an astrovan the other day and i was like dang...i wonder if these would look good on my 4runner...guess i'll be finding out.
Come see me when you need tires for sure, sonofmayhem, any of you. The wheels are made by MB Motoring. We can mount the wheels no problem, and I prefer the abbreviation ASST. Manager, not ass manager...Thank you.
And about the Asst. Mgr. I wasn't meaning the other in any disrespect, it was a mis-key (forgot the 'T'!) LOL SOWWEY!
John
Does anyone know where I might find some ideas for the design of a rear tire carrier? I have a couple thoughts but am looking for some ideas.
Other thing I', looking at doing is sanding the truck down, spraying it with primer and then laying down red again. Is there anyone in Colorado that is good with bodywork and wants to help me remove the rust on my truck and then paint it again?
Brandon
Brandon
Finally got my lift installed on the 22nd. The kit is pro-comp and came with front springs, u-bolts front and rear, new bushings, shocks and struts and AAL's for the rear. Here is a the kit:
After getting the front almost done we noticed a fatal error...You see, the spring perch on the passengers side sits higher so you need a slightly shorter spring. We mixed them up when installing them and the truck leaned...back to square one. Got the front back apart and then back together and installed the tires. Pulled out of his garage and backed in to start the back. The guy that was helping me wanted to take the springs completely off and install the AAL on the bench but I had the ingenious idea of C-clamping the packs together and installing the AAL on the truck...saved a whole lot of time.
The only other problem we ran into was with the shocks. The rears weren't made for the toyota and the bushings were too small. Nothing a little hammer action couldn't fix.
Here is the truck after the lift:
The only thing I am not satisfied with the kit is the rear is still too low. It was lifted just enough to clear the 33's. I am going to be getting some oversized shackles to get the ass end up. That poses my question...Can you do shackles only in the rear or do I need them up front too?
Today, I got to take a vacation day from work. Took this as an oportunity to stockpile some parts. Got this CB:
With a "Tiger" antenna:
Decided to mount the CB on the glovebox. Keeps it out of prying eyes for the most part and isn't too far a reach to adjust.
Started drilling the hole for the antenna, broke two bits and decided that hole was too messed up to continue and moved to the other side. Right before I started drilling I saw a hole that was in the bumper (random) and noticed that it would fit the antenna mount.
Got it all wired and realized I needed a longer line, as it sits now it is pretty taught.
The other goody I picked up today is a "VIAIR" constant duty tank. I looked into all the options (powertank, etc. etc.) and I think this will suit my needs very well. Plus it gives me the option of moving up to 37'' tires when I so desire. And I also got a heck of a deal on it. Guy dropped the price from 475.00 to 360.00.
Here are a couple pics:
Here is the tank:
That's all for now. Not sure when the OBA will be installed because I am not too comfortable with electrical...so if anyone in Colorado is good with wiring and is willing to lend a hand, I would be grateful!
Brandon
Here is the tank:
Brandon
I took her out on her inaugural run today and was rubbing like crazy!! Finally found out I was rubbing on the leafs on the left all the time when I was trying to turn hard left and on the right when I was flexed.
Is there any reason I shouldn't run wheel spacers front and rear?
