1983 Toyota Pickup SR5
#25
#27
Awesome truck! I wish mine was an SR5, I love the looks of those factory stripes on the charcoal grey!... My 83' is the same color, but my dad replaced the box, so I eventually want to paint it to match the cab. Look forward to seeing your truck when you get the lift done!
#28
Ordered a weber carb, front lift, now to find wheels and tires. I'm thinking something like the stock whites but weighing the pain of cleaning them against just buying a set of black wheels
#29
White wagon wheels look awesome.. Totally classic and period correct. Black is too cliche nowadays and they won't contrast near as well as the white will on your gray truck.
#31
#33
Had to stop due to darkness, a couple of questions, do I use the wires that where connected to the stack carb? Also the two metal hoses on the outside of the distributer, where do I route those? Any tips will be appreciated, because I have to finish by monday
#35
Take it apart, clean it and replace the springs. Mine wasn't returning well so I replaced what springs I could find and heated up the main spring and bent it back to a higher tention. Also, make sure that you have not over tighted the throttle linkage on the weber as it will bind up if too tight.
#36
