what to do with my little old 3.slo
#61
A good spark plug socket has a rubber part that snags the plug so it sticks into the socket. If yours is missing the rubber part try a rubber hose that will fit over the top of a plug.
#62
Thanx for the advice I have another question for you I was going through your thread once again...lol...and I got to the exhaust fab. And I knew that I had to fab and exhaust cross over pipe but what about 02 sensor bungs? Becuz making one of those looks rather intimidating...is there a chance I could just use that old piece of exhaust off the donor?
#63
Alright guys I have another stupid question for you...I have been reading a lot of threads (which you may have guessed considering anyone in their right mind that hasn't done a swap like this before should do...lol) and they all mention the 3.0 missing an engine hook but I don't exactly understand what they are talking about...what I have gathered is that they use those hooks for pulling the engine out but the 2 engines I have helped pull we just bolted a chain to the block with two bolts so I'm not sure really what they are talking about and it would be nice to know lol
#66
Not the 3.0... it has 2, the 3.4 is missing one on the passenger side. Yeah you can use a bolt or bolts I guess, its just nice to have the hooks to keep the chains off the valve covers and other stuff. Also the factory hook spots balance the engine nicely.
You can transfer the pass side hook from the 3.0 to the 3.4 but you need to drill a new hole in it.
#68
I left the 3.0 hook on mine in case I ever have to take it out again. You can see a stack of washers was needed on one bolt.
#70
Alright guys Im getting waaaaaay ahead of myself here...but I cant help it now that i was able to get the 4runner out of the mud so i can work on it a bit when i have time, I have been super excited to start the swap even though I know I should keep reading a lot more before I do anything too major yet which leads me to my question...do you guys think I could just change the timing belt or do I need to do all the components that go along with it?
#71
If you are going to be in there anyways, you should really change everything. You do not want to have to go back one day soon.
And hey...you are 16. You need to go have fun!!!!!!!!
#72
Ok then I will plan on changing everything...and when I get the 4runner I will be having fun especially since my best friend is going to b at ait and so I won't be hanging out down town as much...and since I don't have a truck to screw around in the mud right now that won't work either lol
#74
Nice little truck.............except the 3.0
I didnt know that 16 year olds liked Metallica. I thought all you guys were into Justin Beiber??
Anyone from Colorado that can fill him in on the smog laws there? Is he going to be able to put a drivers drop crossover in there and pass inspection? Is there even any inspection, etc?
#76
well i have some great news!!! me and a buddy went out and worked on the 4runner we got the spark plugs out and watched as it shot oil as we cranked it threw them back in and guess what? ya we got it running not for long cuz i was running late for work but i got to hear it run for a little bit hopefully will have time to get it to town tomorrow
#77
ok guys im pretty sure i already confirmed this on someone else's thread but i would like your input just to cross-check that i understood correctly...since i have manual hubs i should not have to worry bout that add plug not being there right?
#78
What ADD plug are you talking about? You can have manual hubs and ADD at the same time, but its not like that from the factory.
#79
well the guy that i bought wiring harness said it was missing the ADD plug but i figured since my truck has manual hubs already i shouldnt need to worry about that...
