is my wiring correct? check it out..
can some someone please lay this out for me.
3.4 from a 97 4runner auto with 98 tacoma ecu
im using the 4runner auto harness it plugs into the ecu
goin in 91 3slo truck manual
heres what i got so far pls correct..
3.0
G-L= speed sensor
G-W= brake? there's 2 ?? help
W-G= SEL? help
Blue= + pump
Y-B=THA?
B-R=ignition 2 fat wire
B-R= skinny wire?
W-R= B+ efi
B-G= Batt
V- check engine light
G-Y= negative goes to COR?
G-W= indicator switch transfer position? help
B-W= A/C clutch? help
Y-Blue= oil pressure
Y-G-water temp
B- tach
G-Y indicator switch? help
B-O= help?
B-R=a/c idle up? help
Blue= help
Blue=help
R-W=help
3.4
B-R= IG2
Blue-r=to detection switch transfer neutral position L4? help
W-R=am2/ help?
R-G= to detection switch neutral position? help
G-B 4wd add to indicator switch? help
W-Blue= B+
G-Y= goes to fuel pump relay - ? help
G-W= brake? help
G-W= oil pressure? help
V-check engine light
B-W= Batt
W-B= clutch pedal
B-=tach
3.0
G-L= speed sensor
W-G= SEL? help
Blue= + pump
Y-B=THA?
B-R= skinny wire?
W-R= B+ efi
B-G= Batt
Y-G-water temp
B- tach
B-O= help?
Blue= help
Blue=help
R-W=help
3.4
B-R= IG2
W-R=am2/ help?
W-Blue= B+
G-W= brake? help
B-W= Batt
W-B= clutch pedal
B-=tach
got it to fire up.. still need help with dash wiring..
http://youtu.be/MIMDfSUA1hc
yeah sounds even better now i had plug wires crossed on that video. i installed all the belt s found out its not charging the battery im using 3.0 alt and harness just extended the power cable to the fuse box, got any idea what wrong im thinking alt.. truck wasn't running when i bought it thanks..
crashburnoveride
07-10-2015 06:39 AM
