Synthetic diff oils?
I've searched on several different boards and can't quite find a definitive answer that suits me, so I'll post my question here:
Is it ok to use Mobil 1 synthetic gear oil in 75w-90 weight in the differentials of a 1997 Toyota 4Runner 4x4 5spd (standard diff, no locker)?
I ask this because the Toyota manual calls for 80w-90 and I want to make sure it's not a problem.
Chris
Chris
I thought that 80w was only for BELOW zero applications?
The Chilton's I'm looking at says 90w for ABOVE zero F.
j/c - what was the price you saw on this Mobil 1 75w/90 and where?
~a
~a
Re: Synthetic diff oils?
The manual recommends 80W90 on my rear diff, but I'm using Amsoil synthetic 75W90 in there right now and I don't see any problem at all. 80W90 is a little heavier than 75W90 so I guess it does not make any difference as long as there is oil in the differential case. The fluid in there is synthetic so I have a peace of mine knowing it will do it's job to lubricate the ring/pinion gear and bearing in there.
Noel
Noel
I was wondering the same thing before I did my fluids and found some info about others switching and using mobil1. Though I don't remember the threads, it was concluded that it was ok to use the same weight in the front and back. I couldn't find anything but 75w-90 at my local auto store. I did the switch last month and haven't had any trouble.
I currently run Redline in both diffs and my tranny. I used 75-90 in the diffs and Redline's MTL 90W in the trans. I've put on about 14k miles without any trouble. It even works with my Lockrite locker.
Originally posted by Faded
Care to expand? C'mon...details!
I single-handedly blew the 3rd gear synchro after an amazing 17.6 @ 76MPH run in the 1/4 in which I beat a coffee-can Toyota Corolla with a 4 foot spoiler and 19-inch wheels.
How do you like them apples?
So maybe it wasn't the gear oil's fault? :pat: BTW, I dig them apples. I once had a no-show-goin', unloaded torsion bar havin', 2" block wearin', 17" Focal spinnin' 87 Yota. Maybe I would have given you a run for your money? Then again, maybe not...it burned so much oil that bystandards thought it was on fire as I roared past. After the axle seals started leaking it would do hella burnouts though!
this was barely touched upon up higher but with a locker should you change to a different gear oil?
Probably a stupid question but I don't know the answer yet :pat:
I was told by Redline that it would work fine with my locker. I would think that most gear oils would work for a locker because they are already designed with shear protection in mind (for the ring/pinion/spiders, etc.) Now if you run a clutch type limited slip (LSD) I would be a little more careful in choosing gear oil. Most manufactures will spec if thier stuff is okay to use in clutch-type LSDs. Most of the time all it takes is a few minutes to read the bottle or call the manufacturer.
Good grief. Once I finally start getting answers, they start flowing in. I still have the Mobil 1 in the diff, but I have all Redline fluids in my garage waiting to be poured in (gonna do the entire drivetrail at next oil change). For the diffs, I bought Redline's 75w90NS. It's a GL5 gear lube without the friction modifiers for LSDs.
I'm going to use MT90 for the transmission (5spd) and t-case.
Chris
Chris
Originally posted by <96 Runner>
I would not go straight 90 in the MT.
http://www.redlineoil.com/redlineoil/mtlti.htm
Chris
So, I'm going to do my tansmission and transfer case soon. The thing is, what weight should I go with? I'm going to be in Bozeman, Montana for the winter. For those of you who don't know, it get's quite cold there. Anyways, should I go with a thinner weight or should I sick with the stock recogmedations
