got problem
Old 05-23-2005, 11:41 PM
884runner's Avatar
got problem
well i just put a new altinator in because my bat. guage would always read about only half way up and my bat. light and brake light wouldn't shut off unless i hit the gas real hard. or they would never even turn off. so after i put the new one in the problems went away. well they are back now and i don't know what to look at now. what else could be the cause????
thanks,
alan
884runner is offline
Old 05-23-2005, 11:42 PM
green91runner's Avatar
your battery could be shot cause of the previously bad alternator.. or less likely, but still possible, the new alt broke from a defect by manufacture.
i don't know if any autostore does it down there, but here canadian tire will test any electrical component for you free of charge, battery, alt, whatever.
green91runner is offline
Old 05-24-2005, 01:04 AM
Greg'sToy's Avatar
tha's a classic symptom of a bad alternator, usually it's just the brushes. since the alternator was recently replaced, you could check your alternator wiring connections to see if they are clean & tight, and still connected.
Greg'sToy is offline
Old 05-24-2005, 02:06 AM
admiral's Avatar
Might also want to check the belt on your alternator. Maybe you didn't tight enough and the belt is slipping causing your alt not to work properly. Check the obvious things first.
admiral is offline
Old 05-24-2005, 08:58 AM
roger's Avatar
Also if you got a rebuilt alternator it is possible that it's defective. I went through 3 of those once before I got a good one. Check the other stuff first, if that doesn't pan out have the alt tested again. Good luck!
roger is offline
Old 05-24-2005, 11:16 AM
heavyrebel95's Avatar
I know from experience with a customers 4runner that toyota alternators will test BAD if your battery is actually the problem. OFTEN the battery IS the problem and it burnt out your original Alternator. Replace BOTH battery and get the Alternator warrantied. Also, if your buying cheap alternators, DONT. Go buy a good one from AC DElco, Toyota or NAPA.
heavyrebel95 is offline
Old 05-24-2005, 10:32 PM
884runner's Avatar
hmm all of these things sould like possible answers to my question but right now i'm too busy to try and find the problem so it will have to wait til tomorrow afternoon. Til then i'll just try one of the other 2 4runners we have. thanks,
alan
Old 05-24-2005, 10:42 PM
Yota4runner's Avatar
Was your battery dead when you started the truck up after installing the new Alternator?
Could be a bad Alternator if its one of the remaned ones, I went through a couple, they gave me free ones when mine went bad. I also got a free batery out of the deal, so I was able to check to make sure that wasn't it. Try testing it with a multimeter, first with the truck off at the battery then with the truck running at the battery. You could also check the alt with the truck running but be VERY CAREFUL as there is fans and pulleys spinning.
Yota4runner is offline
Old 05-24-2005, 10:51 PM
jimbo74's Avatar
about 80% of all the reman alts you get at the parts stores suck and are doa... make sure yours is good.....
my bosses son bought a reman from kragens for his capri... he was like dad, it doesn the same thing again as it did before i replaced it... i overheard and told him to take it back.. he wasliek its new... i was liek take it back and make them test it.... sure enough, it was a bad new alt.....
jimbo74 is offline
Old 05-27-2005, 09:55 PM
884runner's Avatar
well i took the bat. out and the atl. out had and cleaned all my terminals and connections and reinstalled everything and now everything is fine so if the problem never returns i will assume i fixed it and if it does return i will get everything tested but a cleaning was needed so i think i fixed my problem. thanks for all the help guys.
alan
SubiKing
08-21-2021 03:57 AM
theking11863
03-19-2016 09:36 PM
Logz808
07-26-2015 07:09 AM
Jonny246
07-24-2015 12:37 PM
kyletbert
07-17-2015 11:39 AM
Quick Reply: got problem
