5.13-5.29
Also - what transmission do you have? If it's an auto, you're gonna need AT LEAST 5.71's if you want to hold the overdrive on anything remotely uphill or into the wind...
BS - it is no weaker than 5.29's which everyone says are OK. Both have 7 tooth pinions. If you want to be stronger, you have to stay with 4.88's or higher.
Some would even argue that 5.71's are STRONGER...
http://www.gearinstalls.com/410suck.htm
1 Post
I thought they had less teeth on the pinion. So much mis-information floating around a guy gets confused.
