35's with a 4" lift?
So I just picked up this truck a while ago and so far I love it. It has a trailmaster suspension lift aswell as a body lift. I believe 4" suspension and 3" body lift. The only thing I was wanting to do was pull the body lift off. Is there any chance that I could fit the 35/13.5's with just the 4" suspension lift? Any help is appreciated.
Thanks in Advance
Thanks in Advance
Probably not...since the previous owner probably wouldn't have installed the lift unless it was necessary fer the 35" tires.
I think it would rub too much when you take the more aggressive trails. Of course...you could just cut the body work if you take the body lift off...
On my 1990 4runner I am running 35 x 12.5's on just a 4" suspension lift 3.75 backspacing on the rims and a little pinch weld trimming with a little rubbing at full lock and stuffed but can be fixed with a little banging on the rear of the front fenders
You could go down to a 1.5 or a 2 inch but the pinch welds rub with any less, and you will hit in the rear as well.
I Miss my T100, specially after seeing yours
Mine was very simular but Green, you need the body lift is what I'm trying to say, maybe not 3 inches but you need it to fit.
It's not just hte pinch welds that hit, the fender gap is not as big as on a 4Runner and is more square if you will.
Honestly, the bumpers line up, just get some Gap guards and rock it as it is, it looks REALLY good man.
justdifferentials
09-05-2015 06:52 PM
joeynational
09-05-2015 01:54 PM
