General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
backfeeding lights
Old 05-18-2017, 03:05 PM
17dodgebros's Avatar
backfeeding lights
I have a 1995 pickup that has a wiring issue. when I press the brake pedal it lights up the dash and license plate lights. also there is a buzzer going off when this happens. any help would be appreciated
Old 05-18-2017, 10:34 PM
wyoming9's Avatar
Red face
Some place in the brake light circuit you have a poor ground.
Most likely the tail light and brake light sockets or even the bulbs .
A good cleaning should fix your issue .
Another possible cause is physical damage to the harness causing a short to the tail light circuit .
In that case your brake lights would come on with the tail lights
Old 06-02-2017, 05:33 AM
Thanks for help,the problem turned out to be someone wired the trailer hitch wrong
