Switching to synthetic in trans - flush needed?
Redline's MT-90 was one of the only GL-4 gear oils I could find that met the 75W-90, which I need due to a cold climate. So it looks like I'm switching to synthetic (MT-90 is) in the trans and t-case in my '85 4Runner.
Some folks suggest a mild flush, Amsoil makes one, if you're switching dino to synthetic in the motor. Anyone know whether something similar is needed for my transmission?
Forgot to mention this is a 5-speed.
Thanks Scuba.
I just drained it, and got some light-colored foamy looking stuff at the end like you'd get with water mixing in. Hopefully that's from an old problem and I don't actually have water coming in from somewhere. But now I really want to flush it before I put pricey Redline in. I may mix and match ~3 qts of what I have laying around so I can get some sort of lube through and wash out the nastiness. For the "wash" I'll let the truck idle in 2nd gear with the t-case in neutral while my concoction is in there. After about 10 minutes things will be warmer so the fluid will run easier when I drain it again, and it should bring more contaminants with it at the same time.
THEN I'm refilling with Redline and hoping for the best.
Thanks Scuba.
