oil additives
oil additives
My truck smokes on startup when it's been sitting oil. Many people have seen my thread(s).
I just did a head job on it and got new valves and seals (not valve guides.) I was wondering what additives you guys recommend for making the current valve seals swell.
When I did the head job, on the first oil fill up I added some risoline oil attitive. I dont think it was the kind that makes ribber seals swell up.
Anyway, I think it's the actual valve guides that are bad and not the seals, but if I swell the seals will that help? Im using 20w50 oil and switching has really helped keep oil consumption down.
Just a heads up, running that thick of an oil could cause premature top end wear...
Stick to 15w-40 tops...
I heard "Engine restore" works pretty well to help seals seal better... but you need new valve guide seals.... You can only bandaide the problem so long.
FS[PacNorWest]: Parting 2000 4Runner Limited 4WD Marysville, WA
DeathCougar
04-01-2018 11:29 PM
justdifferentials
Just Differentials
08-15-2015 05:25 PM
