LC Engineering advertising new HO alternators
http://www.lcengineering.com/newslet...p?p=view&id=70
Part # Description Regular Sale
1080005 85-92 22R/RE P/U & 4Runner $370.00
1080010 93-95 22R/RE P/U & 4Runner $370.00
1080012 88-92 3VZ P/U & 4Runner $370.00
1080014 93-95 3VZ P/U & 4Runner $370.00
1080016 2RZ/3RZ Tacoma 4Runner T100 $370.00
1080018 5VZ Taco 4Runner Tundra T100 $370.00
1080020 75-87 4.2L Landcruiser $370.00
1080022 88-92 4.0L Landcruiser $370.00
1080024 93-97 4.5L Landcruiser $370.00
1080026 98-03 4.7L Landcruiser $370.00
The Mean Green High Output Alternator is the answer to all of your charging problems. This Alternator provides up to 300% more power than stock. So it can charge any engine application no matter what its' power requirements. Superior design, and precision balanced for smooth operation. The Alternator's tool steel rotorshaft is supported at both ends by heavy duty double sealed bearings. Even the heavy duty solid copper starter windings are sealed with high temperature insulation. That's one reason Mean Green include a 1 year Warranty at no charge on every alternator. Another is the heat resistant, multi-function integrated regulator which continues to operate even at extreme temperatures. The Mean Green alternators put out 100 amps at idle and between 140 amps and 200 amps at RPM's depending on application.
MEAN GREEN!!! Sweet!! They've been availiable for fords and jeeps for a long time, and they are awesome, the last alternator you will ever buy. I can't wait till they come out with Toyota starters
09-04-2015 09:27 AM
1080016, 3rz, 8592, alternator, alternators, conversion, engineering, fort, green, ho, lc, lcengineering, toyota, truck, worth
