I just herculined the crap out of my sexy 2nd gen. (Pics)
So I gotta ask where'd you get the Herculiner? I can't find anything like that stuff anymore, Can tire doesn't carry gator guard anymore. By the way, it looks great.
cool
It looks great. I did the same thing plus the grill, bumpers, and side mirror backs. Make sure to use the UV coating or it WILL fade. I will be putting another coat plus the UV coat on this spring because I did not use the UV coat the first time and it has faded to lighter flat black.
#27
Got mine from Napa, a jug I only used half of and some rollers etc for $70. The jug at CT was around $76 and it was $60 at Napa.
#28
Around the wells I loaded it up with wide painters tape and then marked with a tape measure 3" above the wheel well, then just played connect the dots with a marker then followed the line with a razor blade. Worked out well.
For the straight part, just press the tape down at one end and run over to the back of the truck and press the tape down. Everything turns out straight as an arrow.
#31
Did you add the extra UV protectant, so that it won't fade as bad? I always wondered how it would look, going over the fenders. It looked good in my head but I wasn't sure till I saw yours. I have always liked the color of your rig, now it looks even better.:bigclap:
#34
#35
#37
Looks good Scofco.
I take it you did not get any on your hootus?
How Do I Get Herculiner Off of My Hootus?!
#38
