What would it take to make a high milleage 1st gen 4runner daily driveable?
So I'm really interested in building a 1st gen 4runner. Not a crawler, just a weekend warrior for ski / camping trips and as a daily during bad weather. My other forms of transportation would be motorcycle and bicycle, so this would need to be reliable as a DD when weather required it.
Let's say I found a mostly stock '85 with close to 250,000 miles on it. Assume regular maintenance has been done, so timing chain, water pump, brakes, filters, etc are relatively new as are fluids. What would have to be done / invested to make it reliable? Are we talking full motor rebuild / major tune up / what? Approximate cost? I want to do it right. Step 1 is just making it reliable not putting 35's on it...that can come later. I have another truck but goal would be to get rid of it once the 4runner was ready to DD.
What do you think? Share some info with me please, I'm a Honda guy, never owned a Toyota...
a fairly stock Toyota can do excellent for modest trails but if you wanted a litle more off road worthiness id say slightly larger tires just to bring you up a lil posibly a rebuild with that many miles but if everythings been done you should be okay for quite awhile my dads 87 has 290... miles on it and no rebuild
but for a better awnser you need more info on this truck
auto manual engine etc
Ahhhhh, and heres how to rebuild a 22RE
http://www.toyotaoffroad.com/Article...RE-Rebuild.htm
This looks pretty easy...
its super simple, im only 17. just make sure you have all the right tools. you can do it budget for $500, but thats without any block or head or crank work. have you block bored, your head machined, and your crank turned, but the appropriate oversized eveything you need, along with new timing chain kit and cover and oil and water pump. then get to work!
these truck will last forever thats for sure
since you live in colorado my best advice would be to look in pueblo or co springs but i see the best deals on craigslist pop up in pueblo to many in denver are trying to sell their trucks and not understand that they arnt worth that much i looked at to many 20 year old truck that were bone stock tons of miles burnt oil and had people trying to get 4 g plus in denver
Get in turn the key start vehicle drive as needed repair as needed.
You did say you are talking about a vehicle that was taken care of.
If you are talking about a vehicle that has been sitting for the last 5 years with a tree or two growing through the holes in the floor.
Then you have your work cut out for you.
It is easy to spend a lot of money real quick on doing something like this as where do you draw the line
Don't rule out an IFS rig. It seems that folks with a straight axled 22re often think they are made out of gold or something. For what you are describing as your uses of the truck, any Toyota will do. Get a first gen with IFS, wider rear axle, better steering setup, probably cheaper and have at it. Add a selectable locker to the rear due to your location, armor it up, and leave it on stock size tires or 30's and you will do fine. Maybe down the road you go to a 4.7 t case or dual case. Look at what AxleIke and TC are doing with IFS.
I agree with Wyoming. Its a 25+/- year old truck. Stuffs going to fail eventually.
I agree with BLKNBLU, You might want to consider that a IFS truck will ride smoother and get better fuel economy than a <'86 Toyota. It will be easier to find (more model years) cheaper (for the reason above), and altogether more comfortable to drive every day. Some others have brought up the point that you need to remember that anything that's eligible for antique plates won't be as comfortable or (probably) as reliable as a modern vehicle.
With that said, I personally love driving older Toyota's and DON'T mind the fact that it has no ac, is really slow, and is really loud at highway speed that other people who I give a ride to DO mind.
Manage your expectations, and you'll love your truck
Staff
Hello Travis.. Depending on what you can do yourself, these trucks are easy to work on. I have used different seats to improve the comfort for a big improvement. They wont ever be a Lexus ride, just depends on what you are after.
Just did a 500 mile trip on one I just did and several miles before and after the trip. Just follow the manual and other builds on here and it can be done.
I updated my thread to give you an idea as to what can be done. I have done 3 trucks and now the one I am working on another one. Sounds like you are wanting one for about the same reason as I do. If you start a build thread definetly let me know.
Really depends on how the previous owner treated the truck...
I got lucky and have not had any major issues, some people have..
I would expect issues and deal with them as the come along...
but as mentioned, flush fluids, new hoses, alternator, starter rebuild, new fuel filter, spark plug, wires, dist cap, Rotor, sea foam. Then drive and listen to your truck, many times you will get a warning before something explodes..
That's pretty much it right there.
As others have said don't rule out the IFS 1st gen 4runners. I bought my 89 for 1500$ and after just some minor work began driving it every day. I think it took me a week to work out the little things like exhaust, a ground cable issue and just general maintenance. So far so good with 236,000 miles.
I so much like these IFS vehicles I seem to have a few.
These 86 to 88 Toyota`s I like much better then the 2000 Tacoma that keeps trying to kill me. Every time I crawl under it.
The older vehicles are much easier to work on at least for me.
I see no fault with the IFS in what I do .Getting out the driveway /river can be interesting
Besides it starts every time I turn the key
Here's a question...what's a comfortable cruising speed on the highway in a stockish one? Will it cruise at 70 or 75 without flooring it and the engine sounding like it's going to explode?
keep it close to the stock tire size and you should be able to cruise at those speeds. Ive heard of guys doing that, and commuting in these rigs every day.
Ive got 33's, no sway bar and super soft suspension and get death wobbles at 55mph or over. on 31's I drove 300 miles doing 65 at 3000 RMP's.
