Pro Comp EXPK5055B 4" suspension lift kit feedback for new guy
So im a newb, but i have an 86 singlecab pickup and i wanted to know if anyone has installed the lift kit listed above and if so id like feedback on whether or not it would be a good buy. If not, any other lift kit ideas would be appreciated seeing as how i cant find any others that come with new TBs, or ones that are made for front TB yotas. I could only find ones that were for front and rear leaf springs like from skyjacker and various others. My truck has a 4" body lift on it now that came on it when i bought it but id like a suspension lift to get more clearance and articulation for off roading here in alaska.
thanks
thanks
not sure if any one runs that kit..
school me: new TB's? it is usually considered an IFS Toyota
and that kit according to this link comes with rear blocks...for increased articulation blocks won't do anything for you IMO..consider doing a chevy rear spring swap
I put a pro comp stage II 4 inch lift on my 95 runner and I love it. I got myine at 4wheelparts.com. I did the lift myself took two days to fully complete it. The only difference between the two kits is rear coils rather then rear springs. I would say it would work very good for you. Look at my truck (profile pic) to see what it would look like. Go for it....
I would take the 4" body lift out before the pucks punch through the body and/or shear the bolts off (4" puts way too much leverage on everything). If you're going to off road it, that 4" BL is really bad news. Like Wabbit said, the drop bracket lifts are for the mall - not for better off road ability. They actually reduce your ground clearance from stock. They're also very expensive and since you have to actually cut out a lot of your stock IFS, you can't really ever return it back to stock if you decide that we were right and the lift sucks after you have it for a while. Do yourself a favor... if it's going to be for actual off road ability, take the BL out (maybe replace it with a more modest and safer 1-2" BL if anything). Then go get some ball joint spacers for the front and some Chevy rear springs for the rear like ocdropzone suggested. That will give you better off road ability and be a lot cheaper too.
I personally suggest you stay away from 4Wheelparts because it's better to support our vendors on here which are a 1000xs more experienced and knowledgeable about Toyotas. I have had some really awful experiences with 4WP and would never recommend them to anyone. They are the Walmart of the off road world IMO - but worse.
I would leave the 4 inch body lift on, but if it is hockey pucks I think you should remove them because they will break. I had a 3 inch body lift kit and I put a 1inch plate steel on under the lift and I never had a problem with the body moving on the frame until I started jumping it, after the motor was getting ready to blow. But if its not pucks and you like it, leave it then. I never had a problem and I am sure you wont be beating your truck like I did mine. As for drop brackets I put them on the my truck and never looked back. Go for it if you have money for the proper lift kit. Hope that helps
The drop brackets we are reffering to are for the front suspension (i.e. drop CV lifts). I didn't mean hockey "pucks" (although some people do make home-ade BLs out of them), I meant the 4" spacers that his body is setting on are like stilts an are not very safe. They can also punch through the body with all that leverage and do damage that is not easy or cheap to repair.
No loss of GC over stock.
Expensive? Compared to what? BJ Spacers?
ProComp kit requires cutting of one 2"x2" tab. Nothing else is cut. More cutting is involved in BJ Spacers than a bracket lift.
All-in-all, summed up, "Bracket Lifts and IFS are for pansies, mall crawlers and people who just don't understand real wheeling..."
Definitely get rid of the 4" BL. Get the bracket lift, throw it on (replace the rear springs instead of using blocks) and wheel it. It won't improve your articulation, but it will give you more ground clearance (breakover). BJ spacers might help a bit with articulation, but only .5-1" at the most. So that may or may not be what you're looking for.
If you don't like the bracket lift or if it can't keep up with where you want to go, take it off and explore other options like a SAC. You won't make your money back, but you could always sell the lift. But don't be fooled though- ANYTHING you do to your truck is going to cost you $$$ and there isn't one option that's right for everyone.
Ask anyone who's wheeled with me- I wheel the snot out of my trucks. SA might be my preference, but people do not give IFS the credit it deserves. Even with a "mall crawlin' bracket lift."
I live on an island in Juneau and am moving to Wyoming to go to Wyotech, I don't have much, if any fab skills at this point. But the terrain up here is different from down south, I'm not gonna be doing heavy, beat your truck up off roading anywhere. I don't need a lot of articulation, the lift isn't gonna be just for looks but it doesn't need to be super heavy duty. The body lift is actually a ford f-150 body lift from a garage sale and it's really sturdy. I'll end up doing a chevy swap sooner or later but we don't have junk yards up here where I can go and take what I want for cheap. So getting the parts I need from a chevy will cost more than the pro comp lift itself. Which runs like $1200 with shipping to get it up here. But I'm not gonna be doing any rock crawling or anything serious like I said, more of just a leisurely off road session or just to get a little muddy.
that's not to say there isn't any stress on the factory body mounts or a 1 - 2 " body lift, but if a mount goes though the sheet metal and drops 4" while driving, your asking for trouble. If it drops 1 - 2" it won't be catastrophic.
Yes.
I wheel a lot too, on my IFS so I give plenty of credit to IFS. I surprise lots of Jeep guys with what mine does. But I also know that I have made it up and over stuff that people with DB lifts in my group have gotten hung up on. All this talk is just people's opinions, and that's fine, I just think there are better options out there. YMMV.
