Oil Leak take a look.
Old 01-31-2011, 06:01 PM
Buck87's Avatar
shucks
Old 01-31-2011, 08:02 PM
SlightlyWhat's Avatar
I read through about the gasket i got a form in place gasket from toyota. I'm just waiting to see what I want to tear down now...since essentially...a lot of stuff is off.
Old 01-31-2011, 08:14 PM
MudHippy's Avatar
Originally Posted by tried4x2signN
Good posting. Quick, simple, to the point, and not open to conjecture or conversation.
I object. His link doesn't even work. Quick, yes. Simple, yes. To the point, what point would that be? Open to conjecture or conversation...well...am I talking to myself?
Originally Posted by Buck87
shucks
Nice one!
You're welcome!
http://www.4crawler.com/4x4/CheapTri...ingChain.shtml
Old 02-01-2011, 06:50 AM
Buck87's Avatar
Wink
When I posted the link in December it was working.
Thank you
Old 02-03-2011, 03:10 PM
  #25
Dbcfr's Avatar
we just sleaved Jacob's balancer and replaced his oil pump gasket and front seal it took about 1 hour start to finish he had a oil leak that looked very much like the one you are showing...oil pans can be very hard to remove. start with a heavy gasket scraper and tap it between the pan and the block and work your way around it will come off if you have removed all of the bolts....just my 2 cents
Old 02-04-2011, 12:18 PM
  #26
Everything is done and sealed up.
What I did was get a screw driver...hammer it in there a bit and then got a flat crow bar type deal and just put pressure on it til it started to give. I think it's still leaking though so either might have to do it again or check a different area. It looks like the front. This is my first time doing it so i dunno maybe I didn't seal it right but the back of the pan is the only area i had problems as far as sealing it does. I just decided to put some on my fingers and kinda spread it around on the pan on the back side. I think I have like half of the stuff left.
Old 02-04-2011, 12:59 PM
  #27
Buck87's Avatar
Did you get the pan all of the way out from under the truck?
Old 02-04-2011, 01:48 PM
  #28
streetlancer's Avatar
I did, but i had to drop the front diff along with the oil pickup tube.
Used Permatex Copper Gasket Maker, Its been holding up great.
Old 02-04-2011, 04:55 PM
  #29
Buck87's Avatar
good good
Old 02-04-2011, 07:11 PM
  #30
So glad I have 2wd reg cab. XD
Eggslinger
06-08-2019 03:32 PM
Ladythump
22
11-09-2015 08:53 AM
jakebarrett
07-10-2015 07:15 PM
Coreyr384
07-10-2015 11:13 AM
87blyota
07-10-2015 04:31 AM
Quick Reply: Oil Leak take a look.
