front axle hub stud sleeves
Old 10-05-2009, 05:55 PM
87run's Avatar
i dont know if anyone else has had problems with the sleeves that go over the stud for front hubs removing them i found a good idea to remove them just delete if you have already found this out first you loosen the nuts until they are even with end then leave socket and extension on it and hit extension with hammer the sleeves pop right out
Old 06-14-2010, 10:57 AM
91MONSTER's Avatar
I can't get my hubs off my axle. I am trying to get me drive shafts out of the axle but can't get more then the manual locking hub switch off the axle(front)
91MONSTER's Avatar
does what you said relate to my problem?
Old 06-14-2010, 10:59 AM
91MONSTER's Avatar
I am also extremely green with this site so feel free to email me in case I can't find my way back here, but I will try
Old 06-14-2010, 11:01 AM
Staff
DeathCougar's Avatar
You have to remove the hub body to access a snap ring before you can remove the axle from the spindle.
If you don't take that aluminum hub body off, you won't ever get that axle out.
oldirtydirt
02-23-2020 09:30 AM
88sasturbotoy
08-11-2015 01:56 AM
deepmarsh
08-06-2015 03:44 AM
PlayAwhile
07-20-2015 11:36 AM
ItsJustD
07-07-2015 07:49 AM
Quick Reply: front axle hub stud sleeves
