changing oil pan gasket
Old 09-06-2015, 11:26 AM
EDTECH79's Avatar
I am looking for help with changing the oil pan gasket on my 2000 4runner. I just did an engine swap on her after hydro-locking her 5months ago. If anyone has some good suggestions on the best way to change it so I can stop the oil leak that would be awesome. Thank You
Old 09-06-2015, 12:42 PM
wyoming9's Avatar
Red face
Before you put the engine in the vehicle
Old 09-06-2015, 01:58 PM
EDTECH79's Avatar
Well to late its already installed. lol I didn't think about that until it was installed.
Old 09-10-2015, 09:00 AM
EDTECH79's Avatar
Any other suggestions
Old 09-12-2015, 12:22 AM
wyoming9's Avatar
Red face
Since I never have done this.
I would suggest doing some searching
The hard part is getting enough clearance to get the pan off because of the oil pick up .
Some say you need to drop the differential others say it is just easier to pull the engine.
If your luck is better then mine !!!
You might be able to drop the pan enough to apply a bead of silicone around the pan .
Without cleaning both surfaces .
My luck it would leak worse after attempting this fix then before .
It is a pain in the butt no matter how you try and attempt this.
Old 10-01-2015, 09:41 AM
EDTECH79's Avatar
Thank you buddy. The leak is small, but it don't stop me from getting back on the trail.
smthwsn357
12-04-2023 02:08 AM
09-04-2015 09:27 AM
thefishguy77
07-30-2015 10:59 AM
ryerye13
07-14-2015 08:27 AM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: changing oil pan gasket
