22re enngine timing. Short circuited T terminal did nothing to the engine
I have a 22re engine and thanks to the help of xxxtreme22r I was able to find the T terminal to finally set up the timing./ I went in to short circuit the T terminal to then set it at 5 degrees but inserting the paper clip did nothing remotely noticeable to the engine. I tried to set it to 5 degrees anyways but it appears that its not right because it dies. Any ideas what can cause the engine to not react to a short circuited T terminal? Any ideas of how I can set the timing in a work around manner?
steve miller
10-10-2015 01:40 AM
