Fan rubbing on radiator shroud?
Hey all, recently my radiator fan has begun slightly rubbing against the bottom inside edge of the radiator shroud. It seems to slowly be getting worse, ie: coming into contact more and more over time. I've looked everything over and can't seem to find anything thats obviously wrong so I figured I'd check in here to see if anyone else has had this issue or has some suggestions. I checked the motor mounts and they seem good. Checked the radiator and shroud and everything is nice and tight. Would someoone who has an '05+ Taco mind checking the clearance between the fan and the shroud so I can compare? I have about 2" clearance between the top of the fan blades and the shroud and only a few mm's on the bottom, and under certain conditions it even makes slight contact. You would think I had a body lift or something...but I don't.
Thanks for the advice. I actually found a bunch of info on that problem right after I posted this and I'm coincidentally down in so cal on a work trip at the moment and have an appt to visit Tim @ DMZ Fab so he can reposition the motor mounts back to spec and gusset them heavily to prevent future issues. He's fixed a few Tacomas suffering from this Issue with excellent results as well as done all the fab work on my truck prior to this. His work is top-notch. Anyone near so cal should consider calling him if they need this done to their truck.
Longbed 90
03-11-2019 12:38 PM
FS[PacNorWest]: 1993 4 Runner, V6, 4wd, Auto,
AkitaDog
09-03-2015 09:01 PM
