Wheel stand (ifs sucks)
Old 01-12-2008, 02:46 PM
alexe's Avatar
Originally Posted by 4runnerguy
where is this? you guys are in toronto arent you?
Old 01-12-2008, 02:51 PM
Marc P's Avatar
The last couple seconds of this video shows me on the same spot, taking almost the same line to prove TC wrong in this case......
http://youtube.com/watch?v=epDk4CXvDrc
Old 01-12-2008, 04:49 PM
drew303's Avatar
Originally Posted by tc
Who says with an SAS that you won't wheelstand there ... and have a higher COG ... could end up with a roll instead of a wheelstand.
becauseeee w/ a SAS my body wouldnt roll to the left as severe as that. The tire would would drop down ahelluva lot futher than my tire does now w/ IFS. Thats the problem w/ limited travel of the IFS. Once the tire falls as far as it can then the truck leans over until it hits ground again. Not to mention the tire being stuffed (on the right in this case) doesnt "stuff" very much. If that tire could go higher, it'd bring the COG down.
Dont you have a SAS'd rig tc?
I'll have to make another vid later this year after my SAS is done. =)
Old 01-12-2008, 04:58 PM
eightnine's Avatar
yeah we are all from the toronto area, im in etobicoke and josh is in brampton, this was beside the coke plant in brampton
Old 01-12-2008, 08:53 PM
  #25
tc
tc's Avatar
Yes, I have one of each, and depending on the situation, the SAS is NOT more stable than the IFS. Just because the wheels are on the ground, does NOT mean the situation is more stable. If the body leans over enough to get the COG outside the wheel track, you're going over - that's the laws of physics and incontrovertable.
You're going downhill, the weight is on the front. The driver's side front is going to go down just like it is now. If not, you would have held UP that tire with IFS and the rear would have stayed down.
The situation is entirely different than MarcP, who is, essentially, on level ground. (I also note that he took a different line the second time. Seth/Deathrunner showed the difference)
Old 01-13-2008, 05:42 PM
  #26
GenXr's Avatar
Originally Posted by Prophet_MX
cool video, I did something like that last time I was wheeling. I peed a little. I went snow bashing and thought this drift I hit was softer than it was. little 2/3 wheel action.
GOTCHA! New sig quote tagged!
Old 01-13-2008, 05:57 PM
  #27
GenXr's Avatar
Whether IFS or SAS, it appears that they all got through and had a good time wheeling.
A lot of people seem to bash IFS rigs, but I'd rather wheel an IFS rig than sit at home. At least it's still 4wd.
Old 01-13-2008, 07:08 PM
  #28
norcalsvx's Avatar
$$$$money$$$$
Old 01-13-2008, 09:10 PM
  #29
drew303's Avatar
I agree =)
Old 01-13-2008, 09:39 PM
  #30
Bear80's Avatar
It looked like Deathrunners did as well as MarcP's IMO. I liked watching that long travel in action!
Old 01-13-2008, 09:44 PM
  #31
88wildrunner's Avatar
heres a wheel stand on my truck,
Attached Thumbnails Wheel stand (ifs sucks)-holl-1.jpg   Wheel stand (ifs sucks)-holl-2.jpg
Old 01-13-2008, 09:51 PM
  #32
drew303's Avatar
That should support TC's case.. That looks nearly identical to the obstacle that that I did my wheelstand on and your rig is a solid axle. I was able to get a more direct line compared to you, you're cuttin the corner sharp. I think my rig at that angle would flop over for sure. You're front is flexing more than my truck does in its wetdreams =p
Old 01-13-2008, 10:29 PM
  #33
i was trying to take the turn wider, but gravity and super slick mud sucked me into the bug rut. i was realy close to rolling and luckely my topper hit the tree to stop it. i was able to drive right out of it though.
Old 01-14-2008, 12:05 AM
  #34
TNRabbit's Avatar
To the original poster (drew303): Did you have your sway bar removed? That will make a pretty big difference...
Old 01-14-2008, 10:02 AM
  #35
drew303's Avatar
no sway bar and i reverted back to stock torsion bars.
Flying91
45
04-11-2024 04:39 PM
RaginAsian91
Engine Swaps
03-30-2019 09:17 AM
RaginAsian91
All Other Toyota Swaps
08-23-2015 10:27 AM
Up&Down
08-11-2015 10:04 AM
scottyg486
07-19-2015 05:34 PM
Quick Reply: Wheel stand (ifs sucks)
