W56-C or G58? How can I tell?
Old 11-02-2011, 05:03 PM
Diablo22RE's Avatar
I'm wanting to order a rebuilt transmission from Marlin Crawler, but they said I need to find out which transmission I have. A W56-C or a G58. Someone from Marlin Crawler said that I can tell by looking at the back of the tcase. He said if it has 7+ bolts, it's chain driven and i have a G58 trans. If it has 7 bolts, it's gear driven and I have the W56-C transmission. I assume this is true, so now I need to hop under and check it out. I was just wondering if someone had a picture of their tcase so I know exactly what I'm looking for. (still not too good at the mechanical aspect of cars/trucks) Im 99.9% sure that I know where the tcase is, but I'm not wanting to risk messing up a $2,000+ purchase.
I first thought I had the W56 cause it's seen on my manufacture plate, but maybe it's on all Toyota Pickups?
I appologize if there is a thread for this already. I'm using a iPhone and the search will literally not work for some reason. Thanks!
Old 11-02-2011, 05:32 PM
toyota4x4907's Avatar
You have a W56. G58s are behind '90-'95 4cylinder manual 4Runners and, AFAIK, '89-'95.5 4cyl manual trucks that have ADD (non-manual hubs)
Also, your VIN plate says w56. My '95 22re 4Runner says G58 there.
The transfer case is at the back end of the transmission. The bolts hes refering to are the ones you will see around the outter sedge of the transfer case looking at it from the rear of the truck.
Old 11-02-2011, 05:42 PM
Diablo22RE's Avatar
You sir, are a badass! Thanks for the info and help.
Old 11-02-2011, 06:02 PM
Not a problem. Good luck. Maybe take a picture of your transfer case's rear end and post it to make sure.
Old 11-02-2011, 08:59 PM
Diablo22RE's Avatar
Funny how I wrote this post and started all my research right before my transmission and clutch died. Literally 2 hours after I wrote this post my truck stops driving and I have to get towed home lol.
Here's the picture, looks like there is more then 7..?
Old 11-02-2011, 09:16 PM
BLKNBLU's Avatar
Here is a pic from Marlin as to what you are looking for
Pic comes from their "T case Bible" which is a real good source of info
Here:
http://www.marlincrawler.com/tech/tr...fer-case-bible
Old 11-02-2011, 09:28 PM
Diablo22RE's Avatar
Here:
Wow, that's awesome. Thanks man.
Subaru2.5rsti
All Other Toyota Swaps
17
04-16-2022 06:26 PM
Diablo22RE
03-08-2012 05:44 PM
vsi1600
02-18-2011 03:53 AM
diablo
01-20-2011 03:24 PM
squishy321
02-02-2005 10:47 AM
Quick Reply: W56-C or G58? How can I tell?
