Unable to set timing, 3vze v6 89pu. Timing jumper not working?
Old 03-10-2017, 03:36 PM
infinkc's Avatar
I am trying to get my 89 pickup smogged and when you jumper the diag plug the idle does not drop. Currently you see the timing mark jump around.
v6 3vze
i have adjusted the throttle body and tested the tps. Everything is working.
I dont know where to go from here now. It idles perfect, just doesn't drop rpm with the jumper.
Old 03-12-2017, 05:00 PM
maco35's Avatar
Start by checking your TPS, is more likely to be the culprit here, as soon as you jump the diag plug the RPM's should drop right away. http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Old 03-13-2017, 08:31 AM
infinkc's Avatar
thanks for the reply, i had mentioned in my post that the tps checked out fine and was adjusted. I even tried another tps, no change. So its not the tps at this point. I am thinking distributor at this point. Anyone know where to get one at a decent price?
Old 03-20-2017, 09:32 AM
infinkc's Avatar
Ok, replaced the distributor and the problem still exists!!
Anyone have any other ideas?
I sprayed carb carb cleaner on the vac lines and didn't detect any leaks.
Old 04-01-2017, 10:16 PM
identity's Avatar
Are you certain your jumper is making good contact? I usually have to wiggle the thing around a bit before I get a good connection(verified by the CEL flashing 4x/sec).
Old 04-02-2017, 07:24 AM
infinkc's Avatar
yea the check engine light blinks constantly when it is jumpered.
Old 04-09-2017, 02:28 PM
wadester33's Avatar
I'm having thhe same problem,whem I put the jumper in theres no change and no check engine light,,truck runs fine until warm then sputters and surges,replaced the coolant sensor,,water pump ,o2 sensor,fuel pump,,its a 94 3.0
