Toyota4x4907's 22re build
Old 03-31-2010, 04:16 PM
Lumpy's Avatar
You need an allen key to get it out...Don't rightly remember the size.
Old 03-31-2010, 04:25 PM
Lumpy's Avatar
I circled it in red.
Old 03-31-2010, 04:32 PM
toyota4x4907's Avatar
AH!! Thanks lumpy I do appreciate it. Sadly, I have to go to work so I can't work on the engine until Tomorrow
Bleeder- I read through your thread lots, so Thank you . That power cord, actually cordS, are for the block and oil pan heaters. I will probably take them off eventually. If at all possible, I do not want to take the block heater out, but the oil pan heater is just a pad that is put on with silicone.
Old 03-31-2010, 04:37 PM
iamsuperbleeder's Avatar
ah okay, I see; I would be dumb to that, as there's no real use for a block heater system here in Florida
Old 03-31-2010, 04:38 PM
  #25
Lumpy's Avatar
Not a problem...I'd hate to see ya beak something when it can be avoided.
Old 04-01-2010, 02:41 PM
  #26
Want to talk about luck? The only Allen wrench I could find was a perfect match for that bolt
Also, I want your opinions. I'm planning on selling this head. Should I remove the exhaust manifold or keep it on? I going to get a header so I don't need it.
Also also, do I NEED to have the engine at TDC on the first piston to remove the head? This engine is seized I think and won't budge.
Old 04-02-2010, 02:50 PM
  #27
Well, the engine is NOT seized, thank god. The clutch housing is rubbing against the engine stand it looks like the lower brackets are bent. Three of them were also loose.
Old 04-02-2010, 03:12 PM
  #28
Lumpy's Avatar
Nice...put it down, take it off, and start again.
Old 04-04-2010, 03:40 PM
  #29
From this-
To this-
cylinder #1-
cylinder #2-
cylinder #3-
cylinder #4-
The head gasket-
Some gunk that came out of one of the coolant holes-
I'm about to break the crank pulley bolt and take off the timing cover stuff.
88sasturbotoy
08-11-2015 01:56 AM
Backcountry411
07-24-2015 08:06 AM
PlayAwhile
07-20-2015 11:36 AM
Quick Reply: Toyota4x4907's 22re build
