Steering wheel/column lubrication
Got my first toyota last month...2000 4runner 2WD SR5 Sport. Lately I notice a scraping sound when turning the steering wheel in either direction. My first thought is that the wheel or column needs some grease somewhere. Is this true?
Can I lube/oil/grease the wheel/column? Should I take it to the stealer?
Any ideas most welcome!
Thanks,
sunman
(I love my 4runner!)
Thanks,
sunman
My grant wheel does the same thing. If you remove the steering wheel, there is a plate that the wheel kinda slides on, its for your blinkers and horn contacts. You might be able to grease it with a spray if you remove the coloum cover.
Well its pretty close - I was able to grease mine today by twisting my finger up and onto the plate with some grease. After driving for about 5 mins, the grease moved around and coated everything, all works.
live4soccer7
05-11-2016 06:52 PM
scott90
10-04-2015 09:21 AM
