Steering system issue
Old 03-24-2014, 11:46 AM
MountainRider's Avatar
I have a 94 4runner with 3.0 I just got a couple weeks ago. At first the steering pump started to whine when cold then all the time quickly after that. I lost power steering and got additional whine when stepping on brake pedal. Tried a flush, no fix. Got a remanufactured pump and at first no whine when installed. Still no PS and still whine when apply brakes. Did a bleed with front end jacked up and turned wheel back and forth ALOT. Still no fix. Now a constant but quieter whine from pump. Any ideas? Did I ruin PS box?
Thanks in advance
MR
Old 03-24-2014, 11:55 AM
jdrum1's Avatar
Are you running PS fluid or Dexron trans fluid?
Old 03-24-2014, 12:02 PM
It is ATF
Old 03-24-2014, 12:12 PM
jdrum1's Avatar
There goes my idea.....
Old 03-25-2014, 12:11 PM
So after some disassembly I found there was no union seat between air control valve and PS pump. Could this have caused air to keep getting in? The ATF does not seem foamy. Power steering is somewhat intermittent. Got a union seat on the way, had to order from dealership. How would I know it is still a pump issue vs selector valve or gear issue? I've been all over the forum searching for like problems but to no help.
icentropy
09-16-2020 02:47 PM
coryc85
09-09-2015 06:24 AM
terminator
07-27-2015 07:13 PM
voiddweller
07-15-2015 03:56 PM
Quick Reply: Steering system issue
