Steering
Old 11-22-2008, 08:36 PM
maxigaz's Avatar
Steering
Hi!I need some help.I bought i hydraulic winch and i am going to install it in the near future(hopefully).I have't really gone through the steering lines ,but i can not identify something on the passenger side which is connected to the steering gear and there are some vacum hose as well.I could not find anything in the Haynes only the pump and the steering gear is mentioned?
Anybody has some idea?
Old 11-23-2008, 07:15 AM
FredTJ's Avatar
The vacuum hoses are for the idle kick up (boost the idle speed when you turn the steering wheel while idling). Don't know what else you're seeing.
Get yourself a FSM for your vehicle.
Anything else is a waste.
Also, be sure the check the specs for the winch (required psi and flow rate) and make sure that the ps pump can meeting those demands.
Fred
Old 11-23-2008, 05:15 PM
maxigaz's Avatar
Thanks. At least now i know what is it.
The pump is not ideal really ,but it'll work just gonna be sssslow.i am going to buy a better pump as soon as i get some extra money in pocket.
Can i ask what is the FSM?
Old 11-23-2008, 06:28 PM
FredTJ's Avatar
Factory Service Manual
Fred
Old 11-23-2008, 08:47 PM
Jay351's Avatar
I remember two lines on mine when I replaced the pump. I don't get an idle jump when cranking the wheel, could I have put the lines on backwards possibly?
ladybugRC
458
08-21-2020 10:41 AM
live4soccer7
05-11-2016 06:52 PM
scott90
10-04-2015 09:21 AM
ktm192k
10-01-2015 08:47 AM
gentry
09-28-2015 06:16 AM
Quick Reply: Steering
