SAS axle info needed
Old 05-11-2006, 08:31 PM
Bill's Avatar
All the SAS's I've seen, with the exception of the Sonoran Steel 3rd Gen, have used Toyota front axles. But has anyone used a D44(or mabey D60) from a domestic?
Can anyone tell me the width of the rear axle on a 2nd Gen runner? (xx" WMS-WMS), cause I know that toyota front axles are slightly narrower than the 2nd Gen rear axles.
Also, anyone know if you could get Chevy brake calipers to work with a Toyota master cylinder?
Old 05-11-2006, 08:51 PM
WATRD's Avatar
A D44 on a Toyota and Chebby calipers with a Toy master cylinder?
That's some revolutionary thinking... hahahhahahahahhahahah
A Waggy axle is what you seek...
Old 05-11-2006, 10:10 PM
d0ubledown's Avatar
clicky
and afaik, 2nd gen runners are passenger side diffs, whilst 3rg gen runners & tacos use drivers side diff hence the waggy (wagoneer d44) axle setup in schaefers ride...
Old 05-12-2006, 12:32 PM
Bill's Avatar
cool, exactly what I needed. Thanks.
Now come the hard part...finding stuff.
Old 05-12-2006, 02:39 PM
kyle_22r's Avatar
a modified chevy dana 44 is also a relatively popular swap. i think that most guys have at least the long side cut down to narrow it to toyota width.
Old 05-12-2006, 06:55 PM
Bill's Avatar
Alrighty, in further pursuits of my SAS queriers, how wide are toyota spring perches(as the chevy are 31.5")?
The axle I found in 67.5", while my rear is 58". Anywhere I might be able to find some 2" spacers to widen the rear so I don't have to shorten the axle(mucho bucks)? That and I like a wider stance, especially with the lift I'd get from an SAS.
Old 05-12-2006, 07:39 PM
Cebby's Avatar
https://www.yotatech.com/forums/f152/alternatives-toyota-front-axles-sass-rear-options-too-85702/
Hatch man
08-25-2021 12:54 PM
BigArt70
06-30-2015 09:51 PM
LSUMatt1514
60
10-10-2003 12:30 PM
HALMAN
06-14-2002 09:02 PM
Quick Reply: SAS axle info needed
