Ride Quality (I want new parts)
That's about where they should be which is strange since your bumpstop looks nearly bottomed out, you might crank it down to 13.5" & see if that helps. Other than that I'd agree with everything most others have said, might be dead springs, might go to a softer shock, might replace some bushings or try different tires.
my buddy in his truck has leaf springs in the back, they are more of an arch than mine. Mine are sorta flat, and yes the back does sag compared to the front.
Im probably going to take of my sway bar
Edit: Im having second thoughts...I dont want body roll. Will my vehicle sway more if i replace this swaybar that "sucks"
I'm running without mine & I think the only time it's going to be a problem would be high speed emergency maneuvering - I.E. hard steer left or right at interstate speeds.
Just Chiming in here
I removed my sway bar awhile ago when I was replacing my front cvs and broke the endlinks trying to get them off so I could get the new Axles past 'em. I think it rides better without them. the added body roll I noticed disappeared when I replaced my front shocks.
along the same topic. do others also think the rear sway bar should come off?
my truck is rear spring since it's a 90.
hmm maybe ill try it... I got the adjustable shocks so maybe if it sways too much ill stiffen them up.
The thing is, I want no body roll at all really and a good ride. I cant seem to have both here, maybe if i adjust my shocks.
Would getting an aftermarket sway bar help?
#26
if you're comparing an 91 to an 86, aren't you comparing coil springs to leafs? so apples vs. oranges?
The leafs on my 88 feel really stiff when the bed is empty, but when its loaded up, it rides nice an' soft. Maybe you are just feeling the stiffness of an underloaded set of springs, so its not flexing enough?
Hopefully more peeps will chime in.
*subscribed*
*subscribed*
#28
As Jay said, you could add ball joint spacers and then reset the ride height back to stock via the torsion bars to soften up the front, and add a custom spring pack out back from Alcan since money isn't an issue.
Replacing the bushings would be a good idea too. Even if it doesn't help the ride out any.
#29
If you want NO body roll at all; leave the anti-sway bar on it. It's not going to make the ride stiff, it's only restrictive over big bumps or dips. Soften the shocks & relax the T-bars & you'll find your better ride. If it's too spongy, stiffen everything up just a bit; just be sure to drive it around a bit after adjustments so everything will settle in.
#30
excuse me, this is my daily driver, i dont have the money to throw around for another vehicle. My buddy has a good 91 truck its a 4x4 it has good handling. Give some helpful info plz not some junk like that
#31
#32
I will repeat my statement, perhaps you didn't get it through your thick skull.
You are driving a 22 year old 4x4 with torsion sprung IFS and a leaf sprung rear axle. Do you honestly think you will get it to handle like a sports car?
Suck it up princess.
#33
Get with your friend again and take a picture of the bumpstop just like you did with yours. Compare, then set yours exactly like his. If that doesn't do what you want, then check out all your bushings and ball joints. If that still doesn't do it, then you should probably try the ball joint spacers from sdori.com.
As for the rear, you've already gotten a straight answer about adding springs, otherwise I think most of the new springs out there are for lift. Hope that helps, but Jay's got a point...your 'Runner ain't gonna corner like a sports car, so don't try to make it, the results are usually bad.
#34
guess what, my friend has IFS with torsion springs and rear leafs, just like mine. His layout is exactly as mine... So no as I say again i dont expect it to be as a sports car, just his... tyvm
#35
#36
Shouldn't need any special tools, as long as you have jack stands under the frame and the axle is totally free hanging. May be easier to do the Zuk mod too, try searching for it and there's threads with pictures...virtually NO tools needed! Remember there's also the issue of wheelbase...if your wheelbase is different from your friend's, then you do not have the same setup.
#38
The add-a-leafs don't make it ride rougher they help wore out springs. They do this by putting the load back onto the long springs which are softer.
If you had brand new springs they would make it stiffer.
#39
<-- Consumer Report "truck" tester
#40
Holy crap people.
Okay, first of all, your Torsion bars ARE cranked.
That "thing" you pointed to is your upper bumpstop. If you are riding on it, it means you are at full droop, all the time.
So back the torsion bars off.
His buddy has a 91 truck. No coil springs on a truck.
DO NOT BUY AN AFTERMARKET SWAY BAR!!!!!!!
Why on earth would that change your ride? The sway bar does nothing for the harshness of the ride, your truck will just "feel" softer in turns, because you will have increased body roll. But going straight, it won't make a difference.
Back the torsion bars off, see where that gets you. Don't spend money on crap you don't need, do ONE thing at a time, and see where you are.
