Project 30MPG 22R (86 SR5 pickup)
#61
stop posting and go try this out already because thats the only way it seems your going to learn that this wont work. your not even making the incorrect points anymore like you were, your just disagreeing with people that have more knowledge on this subject then you do and making yourself look like a complete idiot.
and when your done, please take pictures of the setup so we can all laugh at your expense and failure.
#62
Whats not to get about them?
You should look up "turbo lag". They dont stop but when your engine isnt producing enough exhaust pressure to spin them they are only a restriction.
I agree that above a certain amount of boost the fan will cause a very small amount of drag but when the turbo is doing its job the overall intake restriction will be far more of a concern than any correctly operating fan. The fan is not meant to take over the job of the turbo though, it only provides a slightly positive increase to intake air volume due to the restriction of the intake system. It is an alternative to a ram-air or scoop type setup where bugs/rain/mud/water etc may be an issue.
Ah, now I understand why you are reading this all wrong. The fan is NOT inline with the turbo. It is placed before the air filter (or after it, preference and fan performance will determine). The only hot air will be produced by the turbo. The air the fan takes in will be as cool as whatever is going into the mouth of the intake.
BOV's (for exhaust turbos) are for when pressure exceeds or reaches a set point only. At idle a turbo produces no positive pressure. You are thinking of a supercharger.
Cant say I disagree but if you're just gonna buy something and not try to improve it why bother posting on an enthusiast forum other than to wave your wang around?
Skinsfan - Thanks, 2.5" exhaust it will be.. someday
KD - Thanks for the support, class act troll you've been
EDIT
Well said Kiwi
EDIT
Well said Kiwi
a BLOW OFF VALVE expels AIR from the compressor side of the turbo system it releases the boosted air in between the compressor and the throttle body when you take your foot off the gas so that when the throttle body closed yuor turbo dosnt spin backwards these are sometimes called blow off valves or bypass valves the latter reroutes air back into the intake after the mass air sensor on cars that use mass air sensors.
there is something else called a WASTEGATE which uses a spring to actuate a valve on the exhaust side of the turbo system (sometimes on the compressor housing its self somtimes on the exhaust manifold) the valve lets exhaust gas bypass the turbine wheel and thus maintains a set boost level.
you should wait to actually experience turbo lag before you go and try to tell people about it and a fan wont help you there either
all turbos run from exhaust gas. this is all basic knowledge that you should know if youre going to start posting up like a big boy, and you dont. you just sound like a complete idiot to people who actually do know how things really work. do yourself and me a favor and refrain from posting anymore BS info. thanks
#64
Dammit.
I started reading this thread hoping there would be some info on how to mod an engine to get better mileage.
First of all, the hypermiler doesn't work for me. I tried it for a few tanks and saw an increase of about 1-2 mpg average. That isn't enough to justify the aggravation and irritation that driving like that causes. A heavy ass 4cyl truck will not get good mileage. I only get 22 city 25-27 hwy. Getting 23 or 24 city is not worth it. Saves me like 2 bucks at the pump.
So from what I've been able to gather from this thread is that I need a stand alone fuel and air system? Correct? Would the stuff available from LCE work?
I've also read that the 22re is not built for fuel effiecency. I've read that its a tractor motor.
Any info on this LS1? What is that, and what does it come from? Are those 30+ mpg's from cars, or from swapped toyotas? Any car is going to get better mileage than my lifted brick.
Thanks
Thanks
#65
Okay, im not that familiar with 22ret's, but I am going to take a stab at this:
Okay, I am going to think that the 22ret has a VAFM just like my 22re. And this whole thing in the most basic way. If you put a fan in front of it that could flow enough air to make a difference, you are going to cause it to open a little bit more just like you are giving it some throttle. Then the engine is going to add fuel, where is the gas mileage in that.
Also the computer fans I have seen are square with a tiny fan in them. They look they they would just be a restriction. (when you say this i think of a tornado, which are crap and dont work, they actually make you lose power and mileage) They would have to flow a hell of a lot of air to make a noticable difference, and then it would be called an electric supercharger, which tests have shown that they dont work. Also, when you think about it, the "wind" that the fan produces would have no effect on the engine cause the turbo is a restriction.
22re's are just not an efficient motor I am just going to suck it up and pay 4 dollars a gallon at 16 mpg!!! (or 24mpg in my camry )
The secret to gas mileage is power to wieght ratio, and aerodynamic drag. I read in diesel power of a dodge 12 valve diesel getting 40mpg, all they did was improve aerodynamics with cardboard!!! nothing else.
Our trucks are like bricks driving through the air!!
Just my .02
Just my .02
#66
STEvil, I still think you don't quite understand how turbo system works... If you put this fan in order to be efficient, it would need to be in enclosed surround or part of the intake.
Just by looking at this fan, All I see is restriction. There is NO WAY, it would push enough air.
If your idea were to be true, people would use radiator fans in conjunction with intake.. But NO ONE DOES THAT!! Have you seen some of these electric radiator fans?? They are at least 2x the size of what youve shown. If your idea were to work, It would be easier for you to just divert the air from rad fans to intake.. But it doesn't work!
KD - Thanks for educating me on turbos, but you could have done it a bit nicer I do have limited experience with them but I have to say the stock one on the 22RET in my SR5 doesnt spool until well after 2500 quite often.
AxleIke - Modifying the air inlet box and replacing the MAF with one from a Supra is supposed to help a bit. The intention I have with adding the fan(s) is to emulate the modified airbox without needing to expose it to the open air so much where it can suck in water and bugs a lot easier. It is not meant to be the end all save all, just merely something to help. I've never seen the 22R used in a tractor. It (the Gen1) does have a longer stroke than the 20R and 2nd gen 22R which gives it slightly more torque but it was designed and built to be used with the Toyota pickups and SUV's of the mid 80's.
1989Toy4wd - Please read my response to AxleIke. In addition the fan may provide extra low-mid throttle response. Not much but hey, whatever helps I think I agree 22re's are not efficient.. but then again i'm not a huge fan of 4-bangers in general lol.
As to the secret to gas mileage, weight is only a factor when accelerating. When holding cruise your aerodynamics play the largest factor which is why you can put an LS1 in a car and get 25-30mpg vs a 4-banger getting 25-30mpg.
I think I have a copy of that magazine. It was 30mpg (up from 20-something)
Also calculated my trucks mileage. 375km on 55L which works out to about 19.2mpg if i'm not mistaken. Not that bad for a slushbox 22RET brick
#67
But what about the Flux Capaciter? Marty is it Fluxing? I just wasted 15 minutes of my life that ill never get back reading all this crap about a 22RET that wasn't meant to get great MPG!! IT's Torque Stupid The toyota truck was meant to drive offroad and at best get you around town at 22,23mph. Get a K&N filter up front and a good exhaust in the rear and thats about it!
#68
the simplest mod you could do to the 22RET (turbo) for more mileage would be to change from auto to manual shift. just about any automatic has a 10-20% worse MPG rating than the comparable engine in front of a stick shift. you loose a bit of mileage just because of the torque converter.
#70
#72
Dunno if the slushbox in my truck is similar in design to a 700R4 from GMC/Chevy but running the fluid that low would be an extremely dangerous thing to do for them... besides, weight isnt so much the issue as it is aerodynamics.
I do shift it "manually" already somewhat to optimize shift points a bit.
edit - why does the quick reply button seem to not work?
#73
Hey Guys,
From My experience, the manual trans has an 7-10% economy advantage, over an automatic, the reasons being, IMO, power loss from main hyd. pump, needed for auto clutch pak operation, and fluid drive of tourqe converter, which is no longer a loss at cruise, after lock up. there is also more power loss, from running a planetary gear set instead of direct drive gear set.
The 22r is a tractor motor.
Weight, is only a problem when You have to accelerate it (Newton's Law), after it is to speed, You pay no penalty, however....You will eventually have to stop.
Thanks, Kiwi
Thanks, Kiwi
#74
well since he has an auto, if he were to put only fill the trans with 1/2 the fluid, not only would that save some weight, but then the torque converter also wouldnt have to move that much fluid so he should get better mileage. the fins in the converter would also act like a big fan and cool the fluid off to make the trans last longer. he could always just shift it as a manual so that would help mileage too!
#75
if not... go back to your corner!!!
#76
Weight is only factor when accelerating??? I'm sorry, but weight is an issue when it comes to MPG. If you understand the modern EFI system, you'll know that weight contributes to load on the car. Higher load equates to more fuel into combustion, which increases MPG. MPG could be achieved in many ways.. One simple way is WEIGHT (less load), less drag tires for less resistance (skinner tires) , A/F and ignition timing (require stand alone ECU to run leaner at cruise), and gearing (less RPM for given speed). Aerodynamics really don't play much unless you are hitting high speed. Most cruise at 55-70 all trucks will share very very similar resistance regarding aerodynamics.
#77
Hey Herblenny,
I dont think that any one is disputeing the fact that increased weight, plays a large negitive part in fuel economy,....But simply stating, that once the mass (vehicle), is up to desired speed, the fact that it no longer requires acceleration,... Has Much less effect on economy.
Newtons first law simplified: An object at Rest tends to stay at Rest, an object in Motion tends to stay in Motion.
Thanks, Kiwi
Thanks, Kiwi
#80
Gas leaf blower?
lol..
Herb - Aerodynamics play a huge part in fuel efficiency. Weight is nothing unless you are accelerating or going up a hill. Was it page 2 that had the link to the article of the truck with the custom body to achieve better fuel mileage? There's reference on page 3 as well of a diesel doing similar changes to increase MPG as well.
Gearing is a tough one. The "right gearing" is going to depend at what point your transmission locks up at if it is an automatic. Too high of gearing and it will slip all day long. Too low and you rev overly high.
Then you pair gearing to aerodynamics and you have an issue both auto and manual cant overcome. You need to find the most efficient RPM range to run because if your gearing it too low you will have to run lots of throttle to hold cruise where if you have it too high you will be running lots of needless RPM's.
Overall its better to right slightly high because you can just put your foot into the throttle less and it wont hurt as much as running the gearing too low.
lol..
